ssm2019
pucho812
third stone from the sun
Does anyone know if the ssm2019 can run off bi polar supply? I am reading the data sheet but it is confusing...
Wondering if it would work as a drop in replacement for an ina217
that's what I was thinking too.
But mouser had it listed as a single supply voltage vs a duel supply voltage so had to double check. Plus when i read datasheets from other companies they list the max voltage 36VDC vs the individual supplies for each rail.
But when mouser had it listed as a single supply voltage vs a duel supply voltage so had to double check. Plus when i read datasheets from other companies they list the max voltage 36VDC vs the individual supplies for each rail.
It can run off of any voltage rails you like, as long as the max (VCC - VEE) doesn't exceed 36V.
-a
