Good evening gentlemen,
about a year ago a had a job in Berlin and for a week I was commuting every morning and evening for a bit more than 30 minutes. I cant recall why I started to draw the V76 schematic in spice but a some point I had a well working model of the preamp. I played around with that model to get to know the circuit better. Also I read through the V76 threads here in GDIY and gathered quite a bit knowledge about the preamp. During the past year I could gather two Sowter V76 input transformers and four Lundahl anode chokes on Ebay. Output will be some Edcor iron I have here. From the U23 build I have power transformers and a PSU PCB what could do the job.
So I plan to build a stereo unit with PSU included. PSU is regulated with DC filaments. I needed to extend the PSU and designed a voltage quadrupler 12 -> 48V. I am quite curious if this will work. I designed pcbs along the tips and tricks I found in the other V76 threads. I integrated a DI input, skipped all the filter stages. Added in and output pad.
I will use EF86 or PF86 instead of the EF804. All capacitors in the signal path are film. Front panel comes from Frank. He did an awesome job again. I will drive the VUs from a chines VU buffer. The PCBs offers two positions to hook it up. I ll see what works best.
Today I assembled the front panel. Thanks again @gyraf for the knobs. I still live off of them. I will stuff the PSU PCB the next days and make a documentation of the build here. I hope you people enjoy the thread.
Falk
Falk
