Where to "fix" reversed polarity
SubSpec
Untalented lurker
GDIY Supporter
Johnson City, TN
So, I've got a recent acquisition Blue Blueberry that was (apparently) factory modified with a bayonet mount. I suspected when initially testing it that polarity was reversed but as I also got a bayonet fitted Mouse and a bunch of capsules so I had other toys to attend to at the time. Am finally circling back to the Blueberry and did confirm it is reversed.
Simply flipping phase on my pre gets me results that are audibly comparable to what I would expect, which is to say, I *think* swapping at the XLR output pins is likely sufficient.
My question is: Is the assumption swapping at the XLR output okay or would it be a better practice to test further up the circuit for reversal, such as the bayonet connection? Might I expect any different sonic results if that were the case or is the circuit likely to be indifferent to polarity?
Hi SubSpec!
Happy New Year!
You can reverse the connections to pins 2 and 3 on the xlr output or reverse the output transformer wires.
Test the Blue mic next to another mic with the correct phase (doesn't matter if it's condenser or dynamic).
It doesn't matter where you do it, so I would swap it wherever its convenient. But probably at where they modded the mic (bayonet)
In the absence of more detailed info, I assume the bayonet is the capsule connection.
Even though some believe it would, reversing the connections of an externally polarized condenser doesn't change polarity.
I'm thinking more of internally at the transformer, but where ever its convenient. at the xlr is what I would probably do anyways.
Possible explanation which connects the two - entirely guesswork:
With the capsule directly wired to the preamp, one side (e.g. the backplate) was being held at the polarisation voltage and the other (e.g. the diaphragm) was pulled to ground (via a 1G resistor, etc.) and used as the preamp input.
But, if it was modded to make the capsule detachable, one connection had to be ground (i.e. the mic chassis) and only one other connection was available. So maybe they rewired it so the backplate was grounded and the diaphragm was pulled up to the polarisation voltage, and also used as the preamp input (via an input capacitor and high-value FET bias resistor).
The difference between these two arrangements is that, in the first, an increase in voltage across the capsule drives the FET gate more negative while in the second the gate is driven more positive. Hence, the output phase will need to be inverted to compensate. Swapping the transformer connection (either primary or secondary/at the XLR) is entirely the right thing, if so.
