CurtZHP
Finishing up the test assembly of my "Heavy" tube preamp. For the most part, everything works great, but you know the drill...
There's always that one thing. In my case, that one thing is the polarity switch.
You'll see it on the attached schematic. It lies between the output transformer and the output jack. When running a sine wave into the input and looking at the output on my sillyscope, the sine wave does not reverse polarity (flip upside down) when I flip the switch. Instead, the signal apparently maintains it previous polarity and actually increases noticeably in amplitude. This is whether I'm looking across XLR Pin 2 and Pin 1 or Pin 2 and Pin 3.
I pulled out the 10K resistor, thinking that was causing the trouble, but that made no difference.
And flipping the switch upside down and calling it a Pad isn't really an option. I already have a sort of pad earlier in the circuit, so that would be redundant.
The design for this particular polarity switch was shamelessly plagiarized from Jakob's G9 preamp. (I renounce myself, and am whipping my bare bottom with a patch cord as I type this...) Obviously, I've made a mistake in translation, or I've wired it incorrectly. So my first question is, did I get the design right? If that's good, then I can try to determine where I goofed on the wiring.
