Ricardus
WILL SOLDER FOR FOOD
- Joined
- Dec 2, 2018
- Messages
- 2,382
- Reaction score
- 946
Build is coming along nicely. I'm in no hurry so I am taking my time with final assembly. I used to geek out and if I had a day off, I would spend 12+ hours glued to my bench working on things, and my neck and back would pay the next morning.
Anyway, because I'm an idiot, when I ordered the panels, I didn't double check the rear panel XLR cutouts, and just assumed they would be Neutrik D-Series which are the ones I like to use (I know, my bad, hence the idiot part). Turns out they were not D-Series, so I just found out my friend Pat bought a small milling machine, and we were able to mill the holes to accept D-Series. So it all turned out well, and nobody would know any better if I didn't tell them.
I was actually out of zip-tie anchors, so I had to order some of those before I can finish this up. Gotta keep the wiring neat.
Anyway, here's that milled panel with some XLRs in, and a couple that aren't so you can see what we did.
