I tried winding the Marinair/Neve LO2567 transformer today, it is the un-gapped version of the LO1166 with a very similar winding structure.
In CJ docs it states the wire is 0.014'', which is 0.356mm.
I used 0.35mm wire (measured with the enamel coating removed) but it's impossible to make it fit in this bobbin. I had the same exact problem as Moby described in the first post, it just doesn't fit.
here are CJ's specs for the LO2567:
I find it impossible to fit all this turns of 0,35mm wire in this bobbin,
I was winding manually but was putting constant tension on the wire, the maximum brutal tension I could, I also winded it very slowly and did even layers,
The doc states some layers with 70 turns, other with 65, as much strength I put and tension I was never able to put it more than 62 turns in a layer, that was the maximum top turns count per layer, the average was 60/61 turns.
I gave up when I had winded 923 turns, there was not a lot of space left in the bobbin and there was still 603 turns to do plus insulation tape.
This is the moment I gave up, there was not much space left:
I'm convinced there's something wrong in CJ's doc on the wire size, even if a lot of tension was used to wind the original transformers, I was also putting as much strength as humanly possible and I was far to make it fit.
Maybe CJ measure the wire size as 0.35mm (0.014'') but with the coating included, I don't know, it's a possibility, that would make the actual copper wire 0.3mm or 0,32mm in size. But I can tell that winding this transformer with 0.35mm copper wire (with the coating it measure 0,39mm) doesn't fit in this bobbin and it's a completely waste of time.
Also there seems to be something wrong in all CJ's docs on the LO2567 and the LO1166 and that is related to the Insulation.
Cj's states "2 wraps clear poly between layers" but for sure it has to mean 2 wraps between sections and not between layers, otherwise the space would be even less.
But this information is in the two different LO1166 docs and on the LO 2567 doc.
CJ seem to confirmed this in a previous post, although the docs still state the wrong info:
there is no insulation between layers, only sections IIRC, and maybe only yellow tape at that,
I will follow Spencerleehorton advice and wind this transformer with 0,3mm and thats what I advise anyone that want to wind it in the future.
will keep you guys posted
