WTB 2 Elma stop screws
nielsk
Megapopulas, Florida
Somehow I am short 2 of the stop screws for an Elma rotary switch, standard 24 position type like in a Neve piece...
anyone have some spares?
Any idea what the "size" is?  I have some defunct cameras that were given to me by a friend that works at a camera store.  Lots of small screws that can be recovered.
Bruno2000
At the moment I have a thicker lead from a 1N4007 diode in there which works but is not perfect.
Only web place I found with small quantities was here (bottom of the page):
http://www.hificollective.co.uk/catalog/-c-61_127.html
I also need 2, by the way!
Peter
the Screws are M1,4
more places stocking them:
https://www.distrelec.de/ishopWebFront/search/luceneSearch.do?dispatch=find&keywordPhrase=4124-21
https://www.buerklin.com/default.asp?l=e&ch=61702
I have used some copperwire that happens to be the right thickness more than 10 times now. Some epoxy and it stays. (No, i havent't actually lost 10 of these screw but this company around here stocks them cheap and without)
Well they are not an ordinary screw, the threads stop about 1/2 way down down the head so there is bare shaft that provides the stop.
The wire I tried just jammed the switch, maybe a larger size would work, but I am not fond of the idea of using glue in there...
Seems the switches have to be ordered with the stop screws or you don't get them?
here you go:
https://www.distrelec.de/stop-pins-pu-50p/elma/4007-35/210012/en;jsessionid=67489DD44EBBE503333D1B4EE6D71092.daechj012u
best source for anything elma i know.
Percy Audio will sell you some. I've used fully threaded M1 screws with no problem from McMaster.
