If you look at power amp design with bipolar supplies, usually the ground point between the main resevoir caps are linked separately away from the signal ground (as in the + and - of these caps first join together, then get taken to the star ground). This may not be necessary with devices that only deal with line level signals, but is probably good practice nonetheless.
As far as the ultimate star ground implementation goes, don't we already break the rules by joining all the grounds at one particular device, and then taking all the grounds of all the devices and joining them together? Take star ground to its ultimate implementation, and all them green wires that join together in your device should really be taken outside of it, and bonded together at one huge massive ground point along with a million other ground wires from all your other kit...innit!!
Or, we could just use balanced lines between all pieces of gear??
Bjorn
:sam: :sam: :sam: I had one of these in a restaurant in Kensington today...damn they're good!
