I have some Go-between kits coming and JLM is closed for the holidays. So I wouldn't be able to ask Joe. Wanted to start ordering the supplies I would need to rack up some Spectra Sonics.
Which Grayhill switch would I need if I wanted a 10 or 12 position variable pad in 5db steps to modify the 20db variable pad in the kit to go from 0-50db(maybe 60db). I would need a shorting switch correct? Grayhill is only a few miles so getting there product would not be difficult. Which series of switches do they make would be good here? Panel mounting. I was not sure if I needed a single deck or multi-deck. This is my first attempt at racking something. I have only rehabbed stuff up to this point.
Thank you,
Christian
Thank you,
Christian
