> a 1 tube lineamp that can run off the lower B+ available from a 115VAC winding. this would allow me to use ordinary dual 115V primary transformers for the power transformer.
You get ~150V DC. Cut the voltage in half, on the same tubes, you get one-quarter power output, maybe less. If you must drive 600 ohms at nominal +4dBm, NYD's designs are already near their limit with 250V-300V, will not be happy at 150V.
But given a 120V winding, and cheap electrolytics, it is easy to wire-up a voltage doubler to give 300V. Since we have existing plans for that voltage, this is the obvious route.
The other is to redesign around fatter tubes, the ones used in US TV sets, which were designed for adequate performance at lower B+. You get less Mu per tube, but you will use a lower-ratio output transformer, so it isn't radically different gain. You may end up with one more stage mike-to-recorder than a 300V design. You will need more heater power to feed the fatter cathodes, and in a compact chassis the heat can be troublesome (TV set size was ruled by CRT and cabinet size: they ran HOT but not as hot as just a bunch of bottles in a minimum case). TV tuner tubes can be fine mike-amps and +12dBm line stages. V-sweep tubes seem ideal for Line Amp work and strong headphone drivers (even, push-pull, little speaker amps). Tuner tubes are often fairly "bent" for RF AGC action, but if you want tube-sound that may not be bad. The V-Sweep tubes are often very linear, so the TV raster was not distorted.
I'm not sure that, after allowing for heat and passive components, Miniature tubes are any smaller than Octal tubes. Octals are IMHO more robust and easier to work on. Also octal TV tubes approached the zenith of routine high-quality tube production. But if you gotta go mini, 6DR7 ($8) is interesting as a high gain driver with a grunty power side.
There is also the 6HB6/6HA6 which is a mini 10-watt V-sweep pentode with 20,000uMho at 40mA and Mu(G2) of 33. This computes out to triode Rp= 1,650 ohms, workable in a 2:1 2K4:600 transformer. If we can flow that much DC in the winding, that's an astonishing Gv=20 to the plate and Gv=10 to the 600 ohms. If we have to resistor-load it, figure half the voltage gain, still good. At 100V on the plate it really wants to be worked above 15mA for good gain: logical trade-off for lower voltage.
The TV V-Sweep tubes are often available in 13V or 15V-heater versions, and sell for a buck less that way. Tuner tubes sometimes come in 4V versions.
TV V-Sweep tubes will work AT their ratings for a couple hard years: if a TV is on, it is V-sweeping as hard as it can (and they usually pushed the ratings). Tuner tubes usually won't take full rated power for years: if a TV is getting a decent signal, the AGC will reduce tuner current, the rating only ensures no quick-death if the signal goes off the air.
