> THD is quite high -- steady around 11% from 80KHz all the way down to 10Hz.
> input / output levels: -10dbu in, between +4dbu and +8dbu out depending on output loading
load impedance: i tried (virtually) no load, a 600 ohm resistor, and a 1k resistor,
If the THD meter is showing 11% at various frequencies, levels, and loads: the meter is sick.
I would expect higher levels with lower loads to show a clear rise of THD.
Do try a 10K series resistor with the source. If THD soars, you are pulling grid current, which is usually a bad plan. You can "get away with it" when you have 50 ohm sources; but if you have a 50 ohm source, why do you need a line driver? Often we have a consumer output, or a pot, or an EQ network, a medium-high-Z source, and that's why we need a line driver.
