Balanced to Unbalanced Line-level
Philgood
Member
would here fit any "Unbal" transformer put in reverse just taking care
of the right impedances ?
i have a 60meters line signal to an amp which has only unbalanced line
inputs. of course i'm getting a lot of buzz sounds from the lightning controls when it's in use.i'm just searching a fast and cheap solution and was thinking of a transformer. do you have specific models/trades in mind for this purpose.
Balanced(line-level - Unbalanced(line-level)
phil
Sombody has to do it:
http://www.edcorusa.com/transformers/wsm/wsm.htm
Depending on your application, one of these might work fine and save you some money. In a live sound setting, I know that I've never needed more accuracy or bandwidth than these can provide.
Did I mention inexpensive? :grin:
So my only problem will be to get such transformers here
down in south spain, thanks a lot buddies.
