Minion
Hi Guys, I am Pretty new to electronix so excuse me if my questions seem stupid....
I am in the Process of Building an Older version of the Green pre (MK1?) as my first real DIY electronix Project , I have Built Mics and replaced the Opamps in my Amp and Built a Battery Powered Phantom supply but nothing this complex....
What I want to know is I have some Small Transformers that I would like to use in the Power supply but they aren"t the Type used in the "Official" Green pre Power supply so I was wondering First If there was a way I can use these transformers in the Green and secondly what would I have to change in the Official Power supply to make it work with these Transformers....
The Transformers are 110v/220v to 2 x 26v rated at between .5 and 1 amp(I haven"t measured it with my DMM yet) and I have quite a few of them so I can use more than one if I have to...
I think I can get 2 x 26v or 52v when running off the 110v Leads so I should be able to get 2 x 6.5v or 13v when running the 220v leads off of 110v Mains....
I"m thinking I can use one Transformer and run it off of the 220v Leads and get 13v AC which should be about 16v DC that I can regulate to 15v which is what the green runs off of ,and I can use another Transformer in series to try to get the Power for the Phantom supply but I don"t know how I would do that?.?..
Does any of this make sence??
Is it possible without to much trouble??
If so How would I do it?? what Mods?
Or is there a way I can use these Transformers with the Green power supply without any real Modifications??
(I don"t think I can regulate 26v to 15v without frying the Regulator??)
Or is there a Schematic somewere for a Green that uses a 2 x 26v Transformer??
Any help would be great...
ThanX a Lot!!! :wink:
