John Noll Active member Joined Oct 29, 2004 Messages 36 Aug 14, 2006 #1 I'm going to rack up a 902 de-esser module and have had no luck finding the pin out info for the 900 series modules. Anyone have this info? Also, what are the power requirements? Thanks.
P peterc Well-known member Joined Jun 4, 2004 Messages 2,275 Location Johannesburg, South Africa Aug 14, 2006 #2 John Try Corey Eng http://www.geocities.com/siliconvalley/peaks/5212/introduction.htm he has a lot of dbx data & circuits. Been very helpful in the past. Peter
John Noll Active member Joined Oct 29, 2004 Messages 36 Aug 15, 2006 #3 Thanks for the links. Interesting that the pinouts are indicating both 15 and 24 volts. Anyone know if this is to accomodate different power supplies (such as the Aphex) or are both voltages required for these modules to function?
pucho812 Well-known member Joined Oct 4, 2004 Messages 14,948 Location third stone from the sun Aug 15, 2006 #4 I know the aphex modules are interchainable with said units... SO I can stick aphex 9000 modules in a 900 rack... :thumb:
