Pultec MEQ-5 EQ full schematic
« on: September 10, 2006, 11:01:42 PM »
I cant find the schematic for the Pultec MEQ-5 EQ amplifier section with the Triad HS50. Has someone got it somewhere?
an I tripping or is the output section a Pultec MB1 mic pre??????
rotation
« Reply #1 on: September 11, 2006, 08:51:32 AM »
This eq was discussed so many times that it's really easy to do sa earch and find schematics.
Good luck!
dinesh
« Reply #2 on: September 11, 2006, 11:20:42 AM »
HI
Here is Schematics of Pultec MEQ-5 EQ
http://www.gyraf.dk/gy_pd/pultec/meq5.gif
laitue5
« Reply #3 on: September 11, 2006, 11:53:34 AM »
He?s looking for the amp section.
metal film 1/4W is ok
« Reply #4 on: September 11, 2006, 11:57:32 AM »
Well, the filter section has been posted many times.  But the amplifier portion is a little harder to find.  Let me dig around.  I can't promise anything.
CJ
« Reply #5 on: September 11, 2006, 01:19:49 PM »
I got it.
12 ax into a 6aq5.
hold on...
Frank's Tube Page: www.mif.pg.gda.pl/homepages/frank/vs.html
Guitar Amps: http://bmamps.com/Tech_sch.html
Tekay
« Reply #6 on: September 11, 2006, 01:51:06 PM »
Thomas "TK" Kristiansson
"The Sound Is In The Iron"
www.vintagedesign.se  www.tkaudio.se
CJ
« Reply #7 on: September 11, 2006, 06:35:37 PM »
ok, 259.7 kb, so watch it!
http://vacuumbrain.com/The_Lab/TA/Pultec/MEQ5/meq_5.jpg
before I learned to use a scanner, no doubt.
cross sectorized coils on the 56, only possible on a 1:1 or other low integer, balanced strays for bandwidth.
« Reply #8 on: September 11, 2006, 07:17:17 PM »
thanks CJ
ciminosound
« Reply #9 on: September 11, 2006, 07:54:20 PM »
Is that the manual too. I have so much crap I need to scan..... Only the old school guys can give me sh*t bout thaT!
:sam:
ALMOST......no really... :thumb:
CJ
« Reply #10 on: September 11, 2006, 08:31:01 PM »
where the h have you been?
surfing off the mainland or elsewhere?
Thanks th Greg Boboski for the filter section, never seen a real MEQ 5 filter doc, which is kinda scary, but mine works, so wtf, over?
« Reply #11 on: September 13, 2006, 09:26:38 AM »
hey where is that?
« Reply #12 on: September 15, 2006, 07:36:27 PM »
hey guys
I want to build a EQP1A but I want to use the output section of the MEQ5 because I have the transformers for it.
Can I use one output section in the other - does it give about the same makeup gain?
CJ
« Reply #13 on: September 15, 2006, 08:32:14 PM »
yes, go for it.
no need for a 250 dollah HS 29, my brethren.
letterbeacon
Re: Pultec MEQ-5 EQ full schematic
« Reply #14 on: August 23, 2012, 09:22:14 AM »
CJ (or anyone else that has it) would you mind posting the MEQ-5 amp section schematic again please?
drask
« Reply #15 on: August 23, 2012, 10:22:59 AM »
Yes, I would like to have it too :)
It will be great.
Thank's
QUEEF BAG
« Reply #16 on: August 23, 2012, 04:25:06 PM »
not sure if this is what CJ posted, but it's the same size...
drask
« Reply #17 on: August 23, 2012, 04:37:26 PM »
[/quote
Thank's for this !
I don't think if it's the same. But CJ can tell us that.
letterbeacon
Re: Pultec MEQ-5 EQ full schematic New
« Reply #18 on: August 23, 2012, 05:56:41 PM »
I believe that's the one -thank you very much!
After searching for ages for schematic, giving up and asking for it, I stumble across a second one here: http://www.groupdiy.com/index.php?topic=23004.msg274012#msg274012
It looks to be the same as the one QUEEFBAG posted.
« Last Edit: August 23, 2012, 06:24:14 PM by letterbeacon »
Last post November 13, 2006, 03:49:29 PM
by W DeMarco
Last post August 04, 2006, 08:06:11 PM
by craigmorris74
Last post June 19, 2007, 06:44:03 PM
by CJ
Last post June 16, 2019, 07:03:18 PM
by pucho812
