G
Guest
Guest
Torroidal - Avel
Primary 120 v + 120v
Secondary 18v + 18v
Built 1992
found a datasheet on the web
60VA
Secondary current 1.67
13% temp rise at 50
Is this way overspecced for any of the DIY projects
A few questions on transformers...
If you buy a big one - do the modules just draw the current they want ?
what happens to tthe rest of the current?
Or does it give you just more "headroom" ?
There is no mounting plate - just a hole in the middle of it - can you buy these separately - the data sheet says M5 screw
Secondary 18v + 18v
Built 1992
60VA
13% temp rise at 50
