Just bought a Transformer of ebay for £1.60 - what use is it
G
Guest
Guest
Torroidal - Avel
Primary 120 v + 120v
Secondary 18v + 18v
Built 1992
found a datasheet on the web
60VA
Secondary current 1.67
13% temp rise at 50
Is this way overspecced for any of the DIY projects
A few questions on transformers...
If you buy a big one - do the modules just draw the current they want ?
what happens to tthe rest of the current?
Or does it give you just more "headroom" ?
There is no mounting plate - just a hole in the middle of it - can you buy these separately - the data sheet says M5 screw
As long as you can accommodate the physical size of the transformer,this will be ideal for many +/-15V projects.
Make sure you understand the important mounting restrictions:mounting pin/plate to connect to one chassis surface only.
the rest is reasonable assumptions,no one knows the truth about instanteous peaks....
Robert
Then you pay too much and need too much space. It may run a bit cooler, but there is some heat at no-load.
At 2 bucks, the "pay too much" is a non issue. And many systems can spare space for an oversized transformer.
That's enough for 50V or +/-25V DC at 0.6A DC. Not really right for an 8 ohm loudspeaker amp. Ideal for regulating to +/-18VDC if you have less than about 100 chip op-amps to power. For a more typical 10-chip project, a 20VA transformer is ample, an inch or two smaller, and at market price for iron, about 5 or 10 bucks cheaper.
Oh, and you have to pick your rectifiers to be bigger than the transformer. If you use a little 20VA job, you can get away with 1N1004 1A rectifiers. With a 60VA transformer, even if you only draw 0.020A steady, you need 3A or larger rectifiers to handle the high current available to charge the filter caps. At $2 for the iron, you can buy 3A rectifers and still come out ahead. (And in practice, 1A rects will probably last many-many start-ups, but if they fail short they burn up your transformer, no bargain.)
