I am unsure what you need 5 volts at that high current for.
You are treading on thin ice.
Phantom power normally is limited to 10ma max. As the 6.81K resistors
in the voltage feed line are the main limiting factor.
Switchers will draw a hell of lot more current than that.
the spikes in current draw and getting one quiet enough
will drive you crazy. Do not go there.
Go here if you must.
http://www.cadmics.com/e100.htm
With the manual in PDF below.
http://www.cadmics.com/pdf_files/e100_manual.pdf
This mic broke the mold. As they did not use discrete circuits.
They wanted op-amps in there. But they needed more current than phantom could deliver. So they trickle charged 2 - 9V NiMh batteries
with the phantom power. The batteries were charged in 16 hours.
To get the circuit to work for you see schematic on page 4 of manual.
R13 and R14 go to microphone XLR conn. pins 2 and 3
Connection C on bottom goes to XLR conn. pin 1
Remove all circuits to the left of R11 and R12 including R11,R12.
For +5V you will need to add a regulator from V9 and V0 to your circuit.
remove V18, Q2, R3,R9,SW3A (a section only) and you only need
one 9V NiMh batter from B2 to B1 (B2 is pos.)
Short JP1 pins 1 and 2 this will now only drain the batteries
when the phantom power is applied. I.E. when the mic is unplugged Q3 is
not biased on and power does not flow from the battery Through Q1 to your circuit.
Hope this helps.
