SSLtech
this is a thread which has branched off from the topic of Behringer ADA-8000's with dead or dying power transformers.
On investigation of the two which I have here, I suspect that there appears to be a potentially serious design flaw in the power supply, and I think I know how to fix it. It's a $15 fix, though it may void your warranty, so if your unit is still under warranty, -hold off. Once it's out of warranty, you may want to perform the mod... if it turns out that I'm on the right track, at least. :wink:
I'm still looking into the values and details, but the nature of the problem is this: The power transformer is a 230V primary with a 120V tap, NOT a center-tap, and NOT a split-wound primary: It's a 0-120-230V primary.
PART 1: In 230V operation, the entire primary shares the load, and the increased inductance halves the current. In 120V operation, almost half of the primary coil is unused, and the remaining half has to pass DOUBLE the current in order to transfer the same amount of current to the secondary. This means that -all things being equal- 120Volt operation is slightly tougher on the primary.
Fortunately, the primary appears to be rated sufficiently highly to do the job... so long as nothing goes wrong to increase the secondary load dramatically.
PART 2: The secondary windings are just too freakin high. -With a measured 121V RMS coming out of the wall:
The secondary AC voltage feeding the (7805) 5 volt regulators reads 11.2VRMS under load... That means that they are dissipating a LOT of heat... and there are three of them in parallel... right next to the main smoothing electrolytic cap.
The secondary AC voltage feeding the (7815/7915) 15 volt regulators reads 20VRMS under load per leg. The raw voltage going into each regulator is 27-point-something volts DC. They are dissipating a LOT of heat: certainly the heatsink is rather too hot to be comfortably touched.
The secondary AC voltage feeding the 48 volt regulators is 62VRMS. This is rectified up to about 80 volts.
Result: This is fine until one of the regulators decides that enough heat is quite enough, and fails. If it fails hard-short, it loads the rail down, pulling the primary current so high that the primary -which was still managing to cope at 120V- crosses the line into too much, and I suspect that the core saturates. Then the primary just gets hotter and hotter, and eventually it's night-night time.
230V users: If I'm on the right track, you won't have to worry so much about the primary, but your regulators may still be getting just as righteously hot, and they masy still be prone to failure. Even before they fail, they may be 'baking' the smoothing caps.
Can anyone with a 'non-failed' ADA-8000 check this out for me? Do the regulators naturally run too hot to touch?
-If my suspicions are true, I suspect that there may be an easy fix; I've figured out an inexpensive plan which would cool the regulators and also provide improved performance and reliability, -but first I need to check that the hot regulators are normal, and that I'm not instead looking at two units which happen to have some other failure which is heating the regulators excessively.
If I'm on the right track, this is VERY exciting.... -well, for me, at least! :wink:
Thanks in advance...
