8 Channel, 3U NEVE 1073 completed
Hi Martin,
In answering someone elses question, I just reminded myself that I hadnt grounded through 10r... I think this might be the cause of the problem.
I thought I had done everything as per the instructions, but then I remembered this! I'll update the results as soon as I can. Sorry to be a plumb!
Jake
redmojosteve said:
Hi Martin
The PCB's arrived today and they are superb! Thank you very much!
I need to save up some money for the transformers now and search the thread for details of appropriate power supply information which will enable me to supply 4 boards and will be mounted externally. Or at least that is my current thinking.
Steve
I think you could use the SSL9K PSU board.
you can buy it from gustav in the white market
Concerning c9 in BA 283AV, does anyone know if Digi-Key part # 490-3676-ND is a suitable substitute for #P4925 which is no longer stocked?
It is a 100pf 50V ceramic mono capacitor.
C9 is a polystyrene cap...not ceramic. You can find some of these in the specialty capacitor area at Mouser.
EDIT: Pretty much ALL of those pf cap's are styrene's. 'cept the termination cap for the input transformer and obviously the tantalums/electro's.
Then is the BOM incorrect?
Here is the part# listed in the BOM (from Digi-Key catalog)
http://search.digikey.com/scripts/DkSearch/dksus.dll?lang=en&site=US&WT.z_homepage_link=hp_go_button&KeyWords=P4925-ND&x=16&y=15
Hi Guys, Sorry for the confusion; please be sure to use the latest, updated BOM, available for download at the first post of this thread:
http://www.groupdiy.com/index.php?topic=22828
M.
Received 2 EZ1290 boards today. They look very nice. I will order parts tomorrow, now that the confusion over the BOM is settled, and hope to have 2 working preamps in a few weeks.
Thanks Martin.
Hi Everyone,
I've just updated a bunch of stuff in my first post on this thread (page 1). Please be sure to download the latest assembly instructions and BOM as a bunch of parts have become obsolete. I also recommend reading the FAQ at the bottom of my first post.
M.
madriaanse said:
Hi Everyone,
M.
Hi Martin,
great updates, The FAQ is something that is really useful and will prevent the same questions to appear over and over again.
I would like to ask you just one thing, is it possible that you could modify you Trim fader pdf, so that a newbie can clearly know where to connect the shield of the cable (from pcb to fader).
thanks a lot for all your dedication to this project
Hi Martin,
I've almost finished my unit using the 1st BOM, with carbon film resistors but without polystyrene, but I still have to buy C9, C10 and the one on the transfo. Should I take ceramic mono caps like the 1st BOM, or should I get polystyrene.
Is there a big sound difference with the polystyrenes ? Should I change all my mono ceramics ?
Ben.
Hi Ben,
You'll be totally fine with Ceramic. I have updated the original (and added a metal film BOM) due to continued prodding to be even more authentic and the fact that some parts went obsolete. You basically can't go wrong either way IMHO.  :)
Take care,
M.
Thanks a lot Martin !
Just to know for futur project : is there a big difference of sound with the polystyrene caps ?
Ben.
I don't think so, but I have not done any stringent testing. My mic pres (with ceramic) definitely hold their ground next to a well maintained set of originals. Using Polystyrene definitely will not hurt though.
M.
so ive been usin the ez1290 for a few weeks now and it sounds great.
................but it only works properly if i run my soundcards inputs (m-audio delta 1010) at +4dB. if i run them at -10dB i have to turn the input gain up about 3/4 and it sounds extremly distorted...  its fine for when im recording at my studio at +4db but wen i took it to my mates studio it was reacting the same way it was at -10dB ...he has the m-audio delta 44 and its slightly difrent in that u select the +4dB/-10dB on the software control panel (on the 1010 its a switch on the 1u rack).........but changing it to +4 didnt help......i still had to turn the input up 3/4ish to register any sound on the soundcard ins, and by then it sounds extremly tinny and very distorted and i could evan hear the audio from the rack itself! im guessing because im clipping the crap out ofthe neve..........is there a way i can get this rack to work at -10dB and run smoothly on other souncards?
any help wud be awsome, cheers
My guess is that you have a problem with your interconect. (xlr to 1/4?)
The ez1290 have so much gain that you should clip your soundcard  way before the preamp. +4 on the 1010 should be the same as +4 on the delta44.
Hub
Hi
I'm about to finish a pair of 1290, I will put them in a 2U rack.
Am I going into problems if I put some 312 boards in the same rack, sharing the same psu? I've build a powerstation with the 6A bridge.
