[quote author="khstudio"][quote author="jeth"]I have no idea, just an outside guess, but could it not be possible to parallel resistors across the pot to move the center in the opposite direction to putting the resistors in series?[/quote]
:idea: That may be a good idea... I have a feeling that may have also been discussed but I can't say for sure.
Maybe someone else can chime in on this one. :idea:
parallel a resistor across the pot to move the center
[/quote]
Don't think so, but YMMV.
The pot is part of Rin of the summing stage around U5 with feedback resistor R30, actually set to 56.2k.
Paralleling any value to it will bring the total resistance of this pot down with the drawback to loose decreasing values and a different pot bending law.
This stage has a voltage gain with pot ccw of -AV=Rfb / (Rpot + Rseries)= 56k2/(500k+5k62) = 0.111 = -19.1dB and pot cw of -AV=56k2/(0k+5k62) = 10 = +20dB.
The required pot value at center for 0dB in this stage with the given values would be Rfb - Rseries = 50k6.
Increase Rfb to (your pot value at center + Rseries) where Rseries = 1/10th of Rfb and you are there.
Have a look at (unproven paperwork, so someone might doublecheck or try)
this Excel sheet , so worst case will be changing 6 resistors (hopefully less).
-Harpo
edit: see following note
