After 11 long, grueling years, my fourth 1176LN clone is finally finished! This one is about as exact as it is possible to get, using original equipment power, input and output transformers, attenuator, FETs - even the case is an original UREi. I did make several, intentional deviations from the original. The zener diode in the +30V supply has a *much* larger heatsink on it, as this zener tends to deterioriate over time otherwise. I used a precision, 10-turn pot Clarostat pot for the meter zero, making it much easier to get the meter exactly on zero, and I used an 8-pin, socketed, DIP op-amp in the meter circuit, making replacement much easier if it's ever necessary. Here are some pics:
Let me know what you think.
---Joe
![Kenetek_1176_1024.jpg](https://proxy.imagearchive.com/edd/edd500dc193d3f6645f97999e1d8df59.jpg)
![Kenetek_1176_Rear_1024w.jpg](https://proxy.imagearchive.com/78f/78f73192ebb067a0c45b311df87edc3f.jpg)
![Kenetek_1176_Inside_1024w.jpg](https://proxy.imagearchive.com/d7c/d7c54fabcd1b01a2cbfb776ba28b3e3b.jpg)
---Joe
