insideout
Active member
[quote author="PRR"]http://twin-x.com/groupdiy/albums/userpics/pd7017.pdf
Gain-range 40dB-80dB is rather frightening for rock-n-roll.
Input iron is connected 1:5. NE5534 feedback minimum gain is 5. Total gain 25 minimum. Rails are +/-12V, peak output say 10V, 7V RMS. 7/25= 280mV maximum input at 5534 clip (I dunno if the iron will take 280mV heavy bass). It will be widely useful, but for all-purpose use you want a 20dB pad in front of the transformer. [/quote]
I'd like to clarify whether that pad should be before the input or output tx. If it goes before the input transformer, won't I be padding down a perfectly good signal and then amplifying that, which would not be an optimal signal/noise ratio throughout the chain?
Would I achieve better results padding down before the output transformer?
