musika
Re: mounting toroid to case bottom. bolt too big and case won't fit in rack
« Reply #20 on: February 12, 2016, 05:13:00 PM »
"....the vice as a purely mechanical tool is indispensable; and no workshop crammed with electronic devices can do without it."
Invented in 1750.
http://www.heuer.de/en/company/history-bench-vice/
PRR
« Reply #21 on: February 13, 2016, 12:01:33 AM »
> Invented in 1750
The sliding-jaw vice.
As that article says, Jesus' Dad probably had a vice; such things may have been old when Moses was a boy.
« Last Edit: February 13, 2016, 10:02:41 PM by PRR »
Gene Pink
« Reply #22 on: February 13, 2016, 05:21:42 AM »
I was amazed to find that our local police department had a "squad" dedicated to investigating vices. Perhaps they inspect them for safety, parallel jaws, make sure the threads are lubed.... :)
Everybody needs a vice.
Sredna
« Reply #23 on: February 13, 2016, 06:56:08 PM »
If you have two of the  dished mounting plate washers (that comes with the torodial) and the material of the case is soft enough (aluminium), you can use them as a tool. Put them on each side of the hole (bulge facing up), insert bolt and then tighten the nut until the depression is deep enough.  You can use a flat head bolt made for a square hole (see pic) as well.
Hmm... in which direction do the electrons actually go?
I'm really late to the party on this (found it in a search for PEM nuts), but I've done this with a drill, bolt, ratchet and a little PVC.
You need some STRONG hardware, but essentially you drill a hole where you want the bolt for the toroid to go.  I typically use 1/4-20 stuff for this.  Get a grade 8 or better 1/4-20 bolt that's plenty long (longer than you'd need for the toroid for sure) some matching nuts, some thick flat and fender washers (you might need to upsize a couple of times) and a high pressure PVC or metal pipe.
The order would go something like this:
Bolt --> (thick) Flat washer (or two) ---> hole in bottom of chassis ---> 1" (or so) I.D. metal pipe/PVC --> large fender washer (multiples for extra thickness/strength) maybe a flat washer, and finally a nut.
Grab a wrench and a ratchet and go to town.  The 1/4-20 bolt will pull against the chassis panel and the 1" I.D. pipe will limit the area the 1/4-20 bolt will deform.  Keep crankin' on the ratchet until you create a deep enough dimple to mount the toroid.
Last post January 24, 2006, 10:31:11 PM
by Kev
Last post March 06, 2008, 06:14:30 AM
by TomWaterman
Last post October 18, 2009, 08:51:59 AM
by 12volts
Last post February 17, 2019, 12:56:03 PM
by weiss
