Harpo
Re: Improve your GSSL... for free!
« Reply #40 on: March 06, 2011, 02:56:25 PM »
You could mod it back to the original schematic, but actually you have it already built in. ;)
A common mistake that people make when trying to design something completely foolproof is to underestimate the ingenuity of complete fools.  -Douglas Adams
ptron
« Reply #41 on: March 06, 2011, 03:47:56 PM »
thanks man! i was wondering where were u hehe havent seen many posts from your behalf lately!
greetings man i hope u are well
No, you are correct; $30k for coffee and occasional BJs is considered a good bargain stateside.
http://www.facebook.com/tronmusic
craigmorris74
« Reply #42 on: March 06, 2011, 04:49:22 PM »
Just to make sure I don't mess something up what I try this, in summary, I need to:
1.  Reverse the wires going from A(pole) to A2
2.  Connect A1 to a ground, most easily C1
Is this correct?
Craig
tzman
« Reply #43 on: March 06, 2011, 06:09:43 PM »
Is this correct?
Craig
If you meant
1.  Reverse the two wires going from A AND (not to) A2,
2.  Connect A1 to ground, most easily C1
then yes, that's all! :)
craigmorris74
« Reply #44 on: March 06, 2011, 07:14:23 PM »
Y
If you meant
Yes, that's what I meant, thanks.
« Reply #45 on: March 13, 2011, 12:53:27 PM »
I came across this PDF: http://www.hausverwaltung-heger.de/al_leck_trick/ssl_mod.pdf which supposedly adds a LED to the bypass using only a DPDT toggle switch. I tried to figure out how this works myself but I don't understand the mod, also because it looks like the bypass wires to the front panel board seem to be omitted completely. Can anyone shed some light on it? I already found that some of the suggested points to attach the wires to the PCB can be done easier by using the holes for the 202 VCA's.
Basically what I want to achieve is a DPDT bypass switch that lights a LED when the bypass is NOT active. Preferrably without adding a relay to the equation.
Thanks,  Alex.
Harpo
« Reply #46 on: March 13, 2011, 04:48:19 PM »
Right side of the DPDT toggle forces the audio-VCAs in bypass condition.
For LED on when compressor active, take the 1k5 current limiting R from the upper to the lower throw position of the switch instead.
Drawback of this minimalist version is, the meter will still show the amount of compression that would take effect as if not in bypass. Have the LED illuminate the meter might catch a little of this flaw.
« Reply #47 on: March 13, 2011, 06:16:14 PM »
Hmm, I guess that minimalist bypass LED mod is not what I want after all then. I'll just have to find me a source of affordable miniature 3PDT switces instead. I have a Purusha case with 5mm LED hole and 5mm toggle switch hole for the bypass, I guess that's all prepared for the relay-based bypass option. I'm not going to go that path, if I would do it the relay way it would have to be true bypass for both channels, too complicated for now.
Thanks for the explanation though :)
weiss
« Reply #48 on: October 18, 2018, 12:51:49 PM »
hey man, did you find a way to realize what you had planned? i am looking for the exact same thing!
thanks
Last post October 08, 2005, 05:33:42 AM
by Samuel Groner
Last post October 13, 2005, 01:11:17 PM
by tamtamstudio
Last post February 01, 2009, 08:38:41 PM
by smallbutfine
Last post August 18, 2019, 02:10:17 PM
by iomegaman
