Gates Tube Mixer Schematic
lassoharp
USA
Here's a schematic for a nice little 4 bottle 3 X 1 Gates tube mixer in case anyone's interested.  Bought this from a forum member recently.  Very good sounding amp.
Please note:
The capacitor in parallel with the 6C5 cathode resistor is not an electrolytic.  It appeared to be a mica type (small brown square - like a chocolate mint).  Could not read any code or value from it.  Perhaps a senior member can suggest an appropriate value here.
Also the 1620 cathode bypass cap is an electrolytic.  The question mark is there because it was impossible to read the exact value.  I ventured a guess of 40uF/25V based on size and the use of this value on the following 6J7.
Current draw at 250V B+ is around 20mA
Nice drawing.  25/25 and 50/25 is common on Gates cathodes of this era.  The mica is there for high frequency boost or correction, and was probably selected during QC.  Many Gates schematics state such.
Volume pot is probably drawn wrong.
First three stages draw 1mA, 1.1mA, 2.9mA, total 5mA. This is clear by the helpful voltage notes and the resistance values. (And a small fudge for 2nd stage G2 current.)
Unless that 6N7 is sick, with that voltage and bias it will pull 6mA per section, 12mA.
Total 17mA.
Supply voltage is limited to ~~320V by the 300V cap in the 2nd stage and the 6N7 rating. I don't think a 20% change of supply makes much difference.
PRR
When you say supply voltage limited to ~320 - is this the no load voltage or max at full load?
