canidoit
You've got your preamps and compressors, now all you want and have time for would be one DIY EQ, which would you build and why?
iva dunit formerly known as canidoit
onlymeeee
Re: If you only had one DIY eq you wish to build, which would it be?
« Reply #1 on: November 01, 2009, 12:17:25 AM »
Only one?
Well it would have to be an 8 band eq then:
2 Bands of a tube Pultec. 4 Bands of a GML. 4 Bands of a 1081
« Reply #2 on: November 01, 2009, 01:17:45 AM »
API 550's! 8 channels.
why: because they're great sounding versatile eq's and they sound good on anything and everything.
« Last Edit: November 01, 2009, 04:37:05 AM by danjpiscina »
alexc
« Reply #3 on: November 01, 2009, 02:03:55 AM »
Obvious here - 1081 eq.
Its good.
« Last Edit: November 01, 2009, 02:06:52 AM by alexc »
I ping therefore I am
stefan
« Reply #4 on: November 01, 2009, 03:53:26 AM »
I love my stereo Pultec clone, a combination of teese and two Pultec MidEq:s in the same box would be great.
snipsnip
« Reply #5 on: November 01, 2009, 05:15:28 AM »
Hi Stefan.... is yours true stereo, or dual mono?
Im building something similar at the moment.
« Last Edit: November 01, 2009, 06:31:10 AM by snipsnip »
ytsestef
« Reply #6 on: November 01, 2009, 06:29:03 AM »
Is it a mixing eq or a "mastering eq"?
I guess I would go with a 550A or most preferable a pultec for the tracking/mixing one and the nite-eq (aka 3D-EQ) for an eq that I would put in my master bus. I just can't get enough of the SUB band and the AIR band. Sontec would be a good alternative, if, say... eeermmmm there were no pcb's available anymore  :'(
Stefanos.
stefan
« Reply #7 on: November 01, 2009, 07:00:52 AM »
Dual mono, pics coming up!
snipsnip
« Reply #8 on: November 01, 2009, 08:50:03 AM »
I'll look forward to seeing them!  ;D
« Reply #9 on: November 01, 2009, 09:18:11 AM »
 He did say D.I.Y.
the 550 and 1081 may be a little out there
i'd say if you want more flexable go the
parametric route or close , Igor had a couple of things
if you want more charactor , there's the tubes & passives
or cheap & easy would give you something to evaluate and use
in the meantime , but resale is not as good on the d.i.y.
so don't forget the used market for non d.i.y.
Stagefright13
« Reply #10 on: November 02, 2009, 10:55:04 AM »
Interesting thread! I am kinda afraid to use eq when tracking. Makes me think I didn't mic something properly. But use eq a lot when mixing. Maybe I should make a couple 550's...
John
Amateur experimenter
« Reply #11 on: November 02, 2009, 01:22:18 PM »
He did say D.I.Y.
that's true. but i think the only real reason the 550 is a "little out there" is because of the fact that it's a 500 series module. it would be a lot more user-friendly to build if we had a whole rack space (maybe even 1/2??) to work with.
Stagefright13
« Reply #12 on: November 02, 2009, 01:58:15 PM »
I would also be into something that is rack case style. My lunchbox is full of preamps.
John
stefan
« Reply #13 on: November 03, 2009, 01:20:50 AM »
that´s the one, on top of my 1176 clones
Bluzzi
« Reply #14 on: November 04, 2009, 05:36:34 PM »
For me the nicest I've heard for the kind of music I record is the Pultecs and naturally the 1084  ;D
This one seems nice if you don't need HP or LP filters;
http://www.groupdiy.com/index.php?topic=33996.0
Jim
spica
« Reply #15 on: November 04, 2009, 06:57:07 PM »
What about PeterC's a*p*i EQ project?
http://www.groupdiy.com/index.php?topic=33790.0
Seems simple enough to add a couple extra frequencies if you wanted more.
I haven't built one, but I'm thinking of starting there if I get the budget to build a couple (or a couple couple) EQs.
« Reply #16 on: November 04, 2009, 07:47:57 PM »
550 A or B
with multi switches vibes me out [ but i bought  a couple ]
but of course the more complex the harder to build
what say candoit , can or can't ?
iangomes
« Reply #17 on: November 04, 2009, 08:33:57 PM »
looking at the 550A schematic, it looks pretty easy, no? Other than the dual concentric switches of course.
« Reply #18 on: November 04, 2009, 11:11:35 PM »
I'd build the 550's. the A's have more freq selections (harder to build). also I think the 550's sound better. those are a great all-around rock 'n roll eq! can't get enough of 'em.
Stagefright13
« Reply #19 on: November 05, 2009, 01:38:06 AM »
Well I really go crazy finding the right freqs to accent things. I mostly try to mic it that way. But a good EQ would be awesome. Such as a 550. Then I wouldn't have to spend so much time. I like to track it the way it should be. Or close. Saves a lot of time having it where ya want it. And are usable for mix a second time... Rack mount!
John
« Last Edit: November 05, 2009, 01:44:12 AM by Stagefright13 »
Last post July 16, 2008, 09:17:30 AM
by mikeyB
Last post February 16, 2010, 11:19:03 PM
by mobyd
Last post December 24, 2011, 06:24:00 PM
by zebra50
Last post May 10, 2013, 10:43:01 AM
by kato
