Biasrocks
Re: DIY Hell..S.... EQ? Phaeton Son Of Hellios! FIRE!!!Let's do it!
« Reply #60 on: November 13, 2009, 08:51:06 PM »
2003, V69 schemo #2
http://SharktankPro.com
"I'd rather use an SPX90 than a UA plugin....." Joe Barresi
Biasrocks
« Reply #61 on: November 13, 2009, 08:51:37 PM »
2003, V69 schemo #3
Biasrocks
« Reply #62 on: November 13, 2009, 08:56:54 PM »
1973, V69 Line Output schemo
hobiesound
« Reply #63 on: November 13, 2009, 09:16:54 PM »
thanx for the 2 missing files of the 2003 schematic! Way back can sometime only get you so far......  ;)
greetings,
Thomas
« Reply #64 on: November 13, 2009, 09:51:01 PM »
...more like building a fake sports car and modifying it to something different before it even leaves the drawing board.
Yes, which was the suggested idea. To make it something different, to avoid pissing off someone who could possibly get pissed off about it. To be somewhat considerate i guess.
So...
...if it were to be 'different', I would rather have more of the eq's in a smaller format, because i have lots of preamps. This seemed to offer more at a lesser cost while trying to adhere to the idea of making something different. Also, it seemed to come at the right time for the 500 series cases, of which there are plenty of other folks projects and eq's involved.
« Last Edit: November 13, 2009, 10:01:37 PM by desol »
Biasrocks
« Reply #65 on: November 13, 2009, 10:04:28 PM »
If you look at the schematic, you'll see that the line input bypasses the transformer and goes directly into the first gain stage.
Leave the transformer and the gain set switch out, set up the first gain stage for unity with a single resistor.
Viola, EQ only. :)
Mark
« Last Edit: November 13, 2009, 10:06:08 PM by Biasrocks »
Baltimore
« Reply #66 on: November 14, 2009, 12:43:50 AM »
I'd love to see a 500 series version, with or without mic pre.
« Reply #67 on: November 14, 2009, 09:32:42 AM »
Mark
Exactly, and i had noted this earlier, but then erased it...silly me. Line goes straight into a switch, then bounces over to the pad switch and into 1 on the 51c1 card...i believe. So yeah, no lustraphone involved. Also, i read that Dick Swettenham kept all the cards seperate in the original modules because of problems with oscillations at high levels. The reissue card(that's pictured on the first page) bears no resemblence to this tho...obviously TA had no problems with this.
Gotta go for now...two emergency calls just came in...7:30 am yay.
« Reply #68 on: November 16, 2009, 12:20:09 PM »
OK!  Colin was kind enough to revise the inductor measurements for us.
http://www.audiomaintenance.com/downloads/carnhill_design_guide.pdf
« Reply #69 on: November 16, 2009, 08:19:37 PM »
Yes, I see...From both old and new .pdf's, like from a mystery puzzle, it is possible to
figure out pinouts for most inductors. In new file, for example, missing footprints for VTB9043/44/50/54/55.
Well...Thanx. And, hopefully, the file with all footprints fixed will be there! :)
I working on two PCB versions: Lunchbox format and 1RU. In 1RU version, there will be separate low cut and low boost switches instead of Elma.
What about placing the power supply on-board?
http://www.ij-audio.com
(new site hopefully will be up in July)
« Reply #70 on: November 16, 2009, 08:36:14 PM »
Two versions?  Wow, you like being busy.  ;)
I don't know if I'd put the PSU on board.  Is the 1RU version two channels?  It might be nice to have them as individual boards per channel.  That way you could configure them vertically if desired.  To fit a few in a tall rack case, or to make a small sidecar mixer.
tommypiper
« Reply #71 on: November 16, 2009, 11:34:28 PM »
I second Miko.  PSU off board is better, as separate board.
Imagine a wet, slightly chilled from its gas release and decompression, with water droplets condensing, sucking surface tension, slowly sliding down the side, capped by a healthy virgin froth on top..
hobiesound
« Reply #72 on: November 17, 2009, 06:02:38 PM »
  as a current owner of several original helios modules, and a former owner od several other types of Helios modules, both active and passive eq's, I suggest that going in and out un-balanced is a good idea. I have tried several different trannies in and out, and I can honestly say that they sound best un-transform(er)ed. They sound loads better imho going unbalanced Line-in than Mic in padded. Just give it a try if you don't believe me. Strange, since the mic pres are pure sex! I only have modules with the tiny Beyer trannies at the mo, but I have had Lustraphone, and also some big Sowter inputs on my stolen Active 3 band eq's.(If it was you that stole them, I am coming to get you, and it is going to hurt quite a lot when I find you . . . . ) My life is NOT the same without them.
    Let me know if I can help!
       ANdyP
hi Andy,
do you own a passive eq module? if so would it be too much to ask if you could measure the inductors and get a inductance and DCR values for both inductors? measurements of size (lams, former etc) and maybe a few pics would be even better! i'm wondering since i'm winding a 10H inductor for the low band right this moment.
greetings,
Thomas
« Reply #73 on: November 18, 2009, 07:28:36 AM »
Yes. This info is wellcome.
« Reply #74 on: December 10, 2009, 08:53:53 PM »
Bump. Can't forget this one.  :)
Be nice to have the lustraphone. The sowter is probably pretty good...
Mic pre is nice. Couple anyway...and some 500 series.
strangeandbouncy
« Reply #75 on: December 11, 2009, 05:25:16 AM »
   sorry guys, I haven't had time to follow everything!
   I have 2 different types of passive. I would suggest the ones from MCA Hllywood cansole would be the ones you want to copy - and that's just because they are TURQUOISE in colour . . . I don't know how to measure inductance . . . Help?
       I will take piccies when I can. ie they are in permanent use . . .
     ANdyP ;D
. . . . RUH ROH . . . . .
SSLtech
"A waist is a terrible thing to mind"
Quote from: PRR
Ah, but that was 1999; we don't party like that any more.
Mark Burnley
« Reply #77 on: December 11, 2009, 05:57:23 PM »
Yum!
...now that's a way to spend and evening...
 :o
Mark
O_O tape is life O_O
SSLtech
« Reply #78 on: December 11, 2009, 07:29:04 PM »
An evening???[/u]
-You speed-reader stud, you!
Keef
Quote from: PRR
Mark Burnley
« Reply #79 on: December 11, 2009, 07:44:22 PM »
...yea,
....must've spent too much time with our baby's books-
I only look at the pictures now!
Mark
Last post January 06, 2009, 09:46:30 AM
by diyfanatic
Last post December 10, 2009, 04:09:23 AM
by MartyMart
Last post January 04, 2010, 06:11:49 PM
by strangeandbouncy
Last post February 10, 2019, 09:42:41 AM
by beatnik
