Igor said:Insert can be done with relay and active line receiver/driver....
This complicates a bit and requires +/- audio power supply instead of single + or - 24V
(depending on how old the Hel**s model is...)
Just a thought. Older Hel**s modules were using -24V supply. We need +24V for makeup stage (second half of BA283).
So, why not use +/-24V power supply and power from here switchable insert's balancing driver/receiver?
This way we have (if insert is "on") balanced micpre out and balanced input into EQ.
When insert is off, relay takes care of insert and sound does not passing thru balanced driver/receiver.
hitchhiker said:I agree with Keith, Why find trouble? it's a current product.
hobiesound said:i don't understand the discussion whether to include a line input the original already had a line input.... although unbalanced but that can be solved in a number of different ways if need be.
hobiesound said:...the original already had a line input.... although unbalanced but that can be solved in a number of different ways if need be.
audiovisceral said:Could we incorporate a little circuit we can switch in to electronically (or transformer) balance this line input when the mic in is not being used?
Could be a nice modern upgrade.
MikoKensington said:The idea mentioned a little while back was to pad the signal before the input transformer for line level.
Perhaps Igor can layout the board in a way that can leave it up to the builder how far they want to go. Like leaving off the preamp or keeping it and having solder points for an optional unbalanced in. Which ain't my bag, but I can see how people may want it for mixer inserts.
audiovisceral said:...we're essentially having to run signals through the preamp a whole second time (40 dB pad to mic level, 40 dB gain back up to line), which might add coloration we don't always want.
Ah yes, those are pretty. What's the selling price on those Mike?MikoKensington said:I'm demo-ing the 500 series Helios in a couple weeks. I'm curious to see what they sound like.
strangeandbouncy said:as a current owner of several original helios modules, and a former owner od several other types of Helios modules, both active and passive eq's, I suggest that going in and out un-balanced is a good idea. I have tried several different trannies in and out, and I can honestly say that they sound best un-transform(er)ed. They sound loads better imho going unbalanced Line-in than Mic in padded.
