Kenyon T-6 Input Transformer
CJ
GDIY Supporter
California
that other T-3 was kind of a let down for a junkie like me, so i switched us over to  another inny,
the Kenyon T-6, which is really a step up as far as the build quality,
i will get the coil un done tomorrow.
The P series is the higher quality stuff.  Just don't hack a P-204 if you have one, I need it!
here are a few pics, this wifi thing is sucking the big one right now,
but i will not give in to comcast, no way,
this is the same coil structure as the T-3, only different core, uses a 375 UI  core instead of the L lams in the T-3.
they say 20 K output Z but the turns are coming up short, i think they puff up the ratings,
the darn mu cans were welded shut, i was hopin to at least garner some inventory, but No!
ok so no print becuase nobody should bother building this, but,
lams:  375 UI  20 ea.  80 Ni ?
pri: 4.65 H. D:.276 DCR:178 ohms  760 turns
sec:86 H. D:.156  DCR:4.6 K ohms
imp ratio:  500 : 20 K ohms = 1:40
turns = 1: root 40  ;D
