JoleFIN
I'm nearing completion with a Drip V72. Sound is passing through, but it's so silent I need to turn both input and output pots to max and then gain +30db from Mackie to get around -20dB when recording a normal speech up close to the mic (some Oktava tube for the test drive). The VU doesn't move either, but if get to "brum" the device the needle moves upwards a bit so the VU seems to be working ok. The Boost pot is a series of 12 resistors on a 12 position switch, and it starts distorting the sound (a warm tubey distortion) if turned upwards from the 'zero' position.
So there's not enough gain before the VU but too much gain before the tube "boost"? Anyone have any ideas where should I be looking towards to fix this/these problems?
-J
-J
