pinebox
- Joined
- Mar 11, 2015
- Messages
- 119
Hello. I have a pair of v72s that were racked a long time ago, and I am going through them trying to get them to match in level better. The previous tech has modified them by removing the 1.25k resistor in position 12 and soldering in a 1k pot. I am trying to understand the benefit of doing this instead of using a pot as an input pad before the signal gets to the pre. Since the v72 was designed as a fixed gain and this position has high DC voltage I think I will return this unit to stock and put a trimmer on the input, unless I am advised against that?
