Quick G7 Question
marktokach
New Braunfels, TX
How does the tube pcb connect to the main pcb? Do I use old resistor leads, wire, or something else designed for the task? I imagine they should be as short as possible. Maybe even shielded. TIA
As Roddy says, solid core wire / thick lead trimmings work just fine. If the wire is thick enough it'll support itself without glue.
I think I used pins from an L-shaped edge connector, something like this:
just pull them out from the connector.
