Kingston
Here's what I've been working on lately.
At heart it's a "one bottle" 6SN7 preamp with a unity gain treble and bass tone stack between the 6SN7 input and output stages. Then there's a whole separate line amp as the output stage. I have already used this line amp in several other projects and basically don't want to live without it anymore. If you don't need the gain the line amp part can be considered optional, but it will also happily drive a 2:1 output transformer and sounds wonderful when overdriven. The V1B stage alone (6SN7 or variant) used as output will need at least 5:1 ratio.
There are just about no tricks in this, as any tube guy will quickly see. I don't intend to cover any new ground here. I'm just gluing together some proven solutions I like, and as such I don't really deserve any credit for it. Advanced copy and paste with my own preferences for tube bias. This is a draft and I will end up tuning bias, pads and tone stack for best sounding distortion points when I hear them first.
The design is absolutely loaded with features and switches, most meant to be relays to minimise hum when I start laying out the thing. You can downgrade performance in several ways and the unit is basically a template for experimentation with tube distortion. There's a possibility of feedback, no feedback, over-bias, under-bias, cathode bypass, no cathode bypass, starved plate and what else! At optimal settings it will be a turbo-charged clean preamp with plenty of headroom. When all options are switched to "completely wrong" it makes various types of distortion/overdrive. Will work great for line level sources, and that's what I will be mostly using it on. I have intentionally biased the optimal settings a bit on the high current side at the expense of raw gain and voltage swing. Tubes seem to sound better this way.
At unbypassed setting max gain is around 75dB (with no output stage feedback).
Cathode bypassed setting max gain is about 90dB (with no output stage feedback).
PSU is a brute force regulated affair with far too much filtering and voltage dropping just in case. This is supposed to be a very wasteful current eater, I don't care.
If you spot errors that will downgrade the design, or have more ideas, now is a good time to mention about them.
I already have a question on the use of feedback. Do I need to add a cap between C7 and R12/R13? Will the R16 somehow screw up (bias?) the tone stack feedback?
What about the output stage feedback? Do I need a similar cap there, or is C12 (connected to output trafo) just fine already?
Mike
[edit]
revision 1.9 with many fixes and various tweaks. There used to be NFD loop around the last two stages, but it was completely pointless. The design does 0.1-0.3% THD+N even without it - mostly second order harmonics, invisible. The option is still there on the PCB. PCB's have seen various levels of development and prototyping too, and these seem to work well, giving the builder plenty of options for further experimentation. The "plate starve" option of the PSU that drops B+ voltage is of the dumb-but-works school of design. It wastes a stupid amount of watts and needs a big-watt resistor, but whatever. The EQ frequency selectors, including the caps are probably best wired directly on rotary switches. The relays limit the choices to only two frequencies per bass and treble control. nF and pF range caps are tiny so this is easy to do.
initial working and well tested release 26.2.2012
http://www.michaelkingston.fi/files/Drive-1_schematic_rev1.9.pdf
http://www.michaelkingston.fi/files/Drive-1_PSU_PCB_1.3.pdf
http://www.michaelkingston.fi/files/Drive-1_overdriving_amplifier_PCB_1.1.pdf
maintenance update 3.6.2013
Note, the above overdriving_amplifier_PCB_1.1 is not perfectly compatible with the below update. PSU was not changed. see this post,
http://www.groupdiy.com/index.php?topic=41509.msg672213#msg672213
http://www.michaelkingston.fi/files/Drive-1_schematic_rev2.0.pdf
maintenance update 21.1.2014
Heater Regulator removed. see this post,
http://groupdiy.com/index.php?topic=41509.msg701614#msg701614
http://www.michaelkingston.fi/files/Drive-1_schematic_rev2.1.pdf
For reference here are some relevant threads that led to this design.
http://www.groupdiy.com/index.php?topic=41313.0
http://www.groupdiy.com/index.php?topic=41412.0
http://www.groupdiy.com/index.php?topic=41371.0
Mike
[edit]
