I was gonna put this in the brewery but think its pertinent to all of our projects. Several projects spec a pcb mount dpdt. The most common pcb mounts that I can find dont have a screw bushing to mount to the face plate, they just float on a board. If you are building boxes that you plan on switching during a mix, I would think twice about using a pcb mount switch if it passes audio and doesnt just fire a relay. Ive got lots of switches like this on my console and some boxes Ive built and Ive just recently had to redo mixes because of noise from the switches. If the switch isnt mounted tight to the front panel of your box, if you use too much pressure, you flex the board or at least the solder joint and this can translate as noise in your mix which is a real bummer. Just thought Id post this as something to keep in mind for future projects. I think for stuff like mute switches, I'll be using panel mount and then running wires to the PCB. So yes, it is convenient to use a pcb mount switch but its not always the best choice depending upon the application.
experience is worth all the gold in the world.
dave
dave
