ruckus328
Figured this was probably a good time to show everyone, I present to you the Send'N'Blend (thanks to dandeurloo for the name).  This is a colaboration with him (who will be doing cases/front panels - hopefully he can post up some pics of the faceplate design).  Now you can add a mix/blend feature to ANY unit.  Big thanks to Keith for the original circuit.
Highlights:
4 Channels of Blend Control / Stereo Links for Channels 1&2 / 3&4
THAT 1246/1646 Debalancing/Balancing
True bypass built in (Options for 2 different sized relays)
External Power Supply will be included (+/-18V & +12V for relays/led's)
Simple, easy to build, nice short audio paths
Will be prototyping in the next couple of weeks, metalwork is already here, boards will likely be available sometime next month.  I'm also going to be prototyping a ribbon cable based front panel control board and db25 rear panel board, which if it works as planned (i.e. no noise) will eliminate virtually all wiring in this thing (cuz I hates me some wiring) - just 4 ribbon cables and your XLR pin 1 wires and you're done.  The option to use individual connectors (as shown below) will stay either way though so you guys can wire it up however you like.
« Last Edit: September 17, 2011, 12:23:35 PM by ruckus328 »
Serpent Audio™ - SB4000 & SA-3A Boards & Parts Kits / SB4001 Preorder / Send 'N Blend
www.serpentaudio.com
kibadachi
Re: Send'N'Blend (Standalone 4 Channel/Dual Stereo) Mix/Blend Design
« Reply #1 on: February 23, 2011, 01:20:24 AM »
Excellent work! This time bigger is better ;D
 Cant wait to get me a couple of these :P
Do you have a price indication?
dagoose
« Reply #2 on: February 23, 2011, 06:31:11 AM »
nice!  ;D
Schems? like to check how things are build.
Da Goose Mastering http://www.dagoosemastering.nl
dandeurloo
« Reply #3 on: February 23, 2011, 10:10:12 AM »
Hey guys these are gonna be very handy!  The case will have the db25 cut outs and all the need cutouts on the back panel.  Here is what the front panel will look like.  Great work Mike.
PROFESSIONAL CHASSIS AND FRONT PANELS FOR DIY PROJECTS: WWW.COLLECTIVECASES.COM
Dan Deurloo
www.collectivecases.com
www.risendrums.com
j.frad
« Reply #4 on: February 23, 2011, 10:17:56 AM »
Looks great, exactly what I've been wishing for!
jsteiger
« Reply #5 on: February 23, 2011, 10:30:08 AM »
Nice!
Visit the CAPI store at http://www.capi-gear.com
CAPI is not affiliated with, endorsed by, or sponsored by API.
snipsnip
« Reply #6 on: February 23, 2011, 12:49:13 PM »
wicked!
mikefatom
« Reply #7 on: February 23, 2011, 12:54:47 PM »
That is some sexy looking board Mike!
Congrats on this and your new born!  ;)
Mike
tommypiper
« Reply #8 on: February 23, 2011, 01:11:03 PM »
What are you guys planning to use these for, exactly?  I'm not sure I get the utility or planned use... parallel compression, adding fx... huh?  ... please clarify. Clearly it's a major effort in design and congrats to all.  Definitely good job to you guys for designing... But what is your intended application, exactly?  I must be missing something.
And all the "looks sexy" comments?  Wha''?!   ::)   You need to get out more often.    ;)  :D
« Last Edit: February 23, 2011, 02:06:12 PM by tommypiper »
Imagine a wet, slightly chilled from its gas release and decompression, with water droplets condensing, sucking surface tension, slowly sliding down the side, capped by a healthy virgin froth on top..
zayance
« Reply #9 on: February 23, 2011, 01:46:00 PM »
I would be interested also depends on price for the PCB, no case for me tough sorry Dan  :P :)
tommypiper
« Reply #10 on: February 23, 2011, 01:53:29 PM »
But what is the intended application, exactly?  I must be missing something.
I definetely love to have parallel compression on a lot of things
....Until now I have to use 2 channels on my desks,so this will help me saving a lot of them.
best regards from germany,
Udo.
Yes, I understand.  I mentioned parallel compression as a sample application.  But why do we need a separate mix/bland box for that?  When we can do it in a mixer...
WHat is this thing's raison d'etre?
tchuss  :)
« Last Edit: February 23, 2011, 01:55:42 PM by tommypiper »
mikefatom
« Reply #11 on: February 23, 2011, 02:54:59 PM »
What are you guys planning to use these for, exactly?  I'm not sure I get the utility or planned use... parallel compression, adding fx... huh?  I don't see the need for all this trouble... please clarify. Clearly it's a major effort in design and congrats to all.  Definitely good job to you guys for designing... But what is the intended application, exactly?  I must be missing something.
Parallel FX, Dynamics, EQ processing.  Four channels of it + the stereo linking feature makes it a nice tool to have around the studio.  You could parallel compress your Snare/Kick/Bass/Toms all separately too!  ;D
If you're an ITB guy and use outboard processing via hardware inserts, like me, having a unit like this can make your life a lot easier since you don't have to worry about phase alignment caused by all the laggy bits of your "digital signal chain".  Not to mention the direct hands-on control it provides.  The more knobs and buttons, the better... at least that's what the geek inside of me is saying... ;)
And all the "looks sexy" comments?  Wha''?!   ::)  Come one, guys.  You need to get out more often.    ;)  :D
You're right, I need a life... I just can't help it!  This darn forum is like a drug. ::) :-\ ;)
ruairioflaherty
« Reply #12 on: February 23, 2011, 03:10:02 PM »
I guess if that if it's not obvious to you then you haven't needed one!
Ruairi
tommypiper
« Reply #13 on: February 23, 2011, 04:08:14 PM »
Why not use a little passive summing box?  Why active?
ruckus328
« Reply #14 on: February 23, 2011, 04:39:51 PM »
Mikefatom - I don't think I could explain it any better than you already did.
This gets requested all the time as a feature/add on for the GSSL & SB4000, and I hear people often wish they had it on an 1176, LA2A, LA3A, etc.  Now you can have it on anything.  And with the stereo link, you could do, for example:
2 Stereo Units (ie: GSSL/SB4000 & Stereo Pultec)
1 Stereo Unit and 2 Mono Units (ie: GSSL/SB4000 & 1176 & LA2A)
Or 4 Mono Units (ie: 1176 & LA2A & LA3A & Pultec)
Tommy - this might not be for everyone, if you're happier doing it all ITB then of course this probably wouldn't be of much use to you.  Why active? - well, why not?  Not everyone likes iron in thier audio path, and this was intended to be very transparent (THAT chips on input and output, one opamp (OPA2604, 5532, etc.), and one cap in the audio path.  If you wanted color you could of course slap some transformers on the outputs if you'd like.
Dagoose - I don't like to post preliminary schematics until things are finalized, but the heart of it is very similar to SSLtech's & Livingnote's CnB schematics, same basic concept, just with the bypass and stereo link added and a little value tweaking.
« Last Edit: February 23, 2011, 04:46:45 PM by ruckus328 »
haima
« Reply #15 on: February 23, 2011, 05:31:04 PM »
Looks great ruckus! I might have to get one of these... and I know a few friends who have been asking for exactly this also.
Are you planning on using pots or rotary switches for the wet/dry controls?
Do people find the tracking to be acceptable when using ganged pots for stereo in this application?
dandeurloo
« Reply #16 on: February 23, 2011, 07:10:12 PM »
I have been doing a number of mixes on a 16 channel Neve/API hybrid mixer and these are gonna be perfect for a number of things.  Parallel compression but I am also excited to use it for reverbs and try it out on eq's.  That is why we decide to call it Send n Blend.  Basically you can send it to anything and blend it in.  Should be very handy to have a few of these around.
Dan Deurloo
www.risendrums.com
sheadstedford
« Reply #17 on: February 26, 2011, 09:52:24 AM »
This looks awsome!
another massive achievment for Ruckus!
Any developement for the sb4000 s'n'b mod? really wanna put it in my SB4000 instead of a stand alone unit.
I like to compress stuff........it makes me happy.
sheadstedford
« Reply #18 on: February 26, 2011, 09:57:44 AM »
too right
helterbelter
« Reply #19 on: February 26, 2011, 12:22:08 PM »
It's looking fantastic, again. Ruckus, you rock...... us !
few questions :
looking at the picture, it looks like it can be cut in 2x 2 channel boards without much hassle. Am I correct ?
And what will the size be ? (of a 2 channel part I mean)
I've been waiting for a while for a balanced CnB / CnB.
Last post February 05, 2012, 08:16:24 AM
by ricothetroll
Last post September 06, 2020, 05:58:26 AM
by znjamznjam
Last post April 23, 2019, 09:16:53 AM
by innercityman
Last post April 12, 2019, 07:13:19 PM
by innercityman
