salomonander
- Joined
- Aug 28, 2011
- Messages
- 913
kambo said:can you measure the resistances on same value inductors.... which changes the Q
you mean simply measure resistance with a multimeter? sorry im a noob
salomonander said:as i have said - im really no expert. but the none carnhill inductors look so much more heathy and are almost the same value. say id find a multitap inductor that has the necessary values and behaves more like the ones i have found at the surplus - would my q change? aaron at don audio does some great custom inductors for fair prices. maybe his work better.
ruffrecords said:salomonander said:as i have said - im really no expert. but the none carnhill inductors look so much more heathy and are almost the same value. say id find a multitap inductor that has the necessary values and behaves more like the ones i have found at the surplus - would my q change? aaron at don audio does some great custom inductors for fair prices. maybe his work better.
If the inductance values stay the same then then there are no other changes to make. It would be interesting to see what Don comes up with. I use him all the time for mains transformers and his work is excellent.
In the meantime I may have found a fix. I have been looking for a way to counteract the rise above 20KHz. The problem is to do it without affecting the flat response. I think I may have a possible solution. To try it all you need to is a 15mH inductor connected in series with 390pF capacitor in series with a 1K resistor. Connect this combination between the junction of the high boost/high cut pots and 0V. It is a series resonant circuit at about 110KHz. Its effect is to tame the tail end of the 10KHz boost. I have only simulated this and only with the 10KHz boost so I don't know if it will have any effect at the other frequencies.
kambo said:yeap, with simple multimeter
edit: Ian has a great documentation on his web btw... all the formulas, tip and tricks...
easy to understand language too! not full of technical jargons unlike some books!
salomonander said:thanks ian,
great to know that you are on it! i do have one of dons multitap inductors that features a 12mh tap. but i dont have any finished pcbs here. can i test this with the inductor alone? otherwise we will have to wait until i built one of the units. or maybe jonas can try this with his unit?
salomonander said:no worries. i sthis something i can test with the inductor alone or will i need a finished unit in order to try?
kambo said:your resistance measurements seems extremely high to me!
i think they should be in "ohm" range not in "K" kilo_ohm range ???
kambo said:these measurements makes more sense.. even if u typed "K" by mistake they dont match with ur first measurements!
just curious... what "lcr" r u using ?
may be add a 1K - 3k3 or something (measure it first) in series with ur inductor and re measure and deduct series resistor measured value from the reading... and compare to other multimeter readings....
salomonander said:alright .... im just swapping around now and values change slightly all over the place. but they are getting closer. i think im too dumb to read the lcr and the measurements done with the reguar multimeter are about right. not exact but about right. way more resistance in the carnhills.
ruffrecords said:The second set of DCR readings seem about the same as I meaure for the Carnhills. I suspect there is something wrong with your LCR meter.
In
