PRR said:
> "push-pull, class A" doesn't sit right
Why not?
There is a deep history of push-pull class A.
Yes I know. I think you believe I was saying that class AB or B is the way to go. Not so. I was referring to only the name, not the actual class of operation. And a bit more specifically, I suppose I was talking about discrete transistor op-amps which was what the topic starter had asked about. Personally, I don't go any other way than 'A' for good audio unless I had to enter in to a little "AB" on big transients.
Again, I just prefer to name these class A operation amps "Balanced" or "Symetrical", "Antiphase", "Totem-Pole", "Differential" or"whatever" myself.
But I realize this won't catch on though
I just think it makes it less confusing when talking about them. As John Roberts stated "Push pull is by definition class B". Having to append "class A" to it because we pushed the B" bit further on out seems a little bit oxymoronic. In "push-pull" "class A" (oops), we are not really pushing and pulling in the classic sense. We are pushing and pushing at the same time.
PRR said:
Class A simplifies power supply design.
Yes it does. And having antiphase betters the PSRR, and being perfectly balanced cancels 2nd, 4th, etc. but not 3rd, 5th etc. and etc.
Thanks for the lesson.
PRR said:
The J. L. Linsley Hood amp referenced by tv is forced to work push-pull class A.
As is the White Cathode Follower.
I know. I tend to think of the J.L.H. as being a class A common emitter stage having an active load though.
And I think of the W.C.F. as a Totem-Pole. I have no idea what Eric White called it though?
Edits: Actually, this still isn't clear as they both have those qualities yes? And also of being a common anode/collector stage with active load. So?
PRR said:
Nelson Pass and many others get bi money for BIG heatsink push-pull class A loudspeaker amps.
Yes he and they do. Most of them are great sounding too.
PRR said:
Push-pull makes class B possible and attractive but not mandatory.
Don't worry, I'm not even attracted to the possibility so I won't be making it my own mandate.
While I'm here, I also have a problem with calling indiscriminately all professional lines "Balanced".
Technically, they are only "Balanced" lines if they are balanced to ground. But we can send from a transformer and receive with a transformer without being balanced to ground. Then it would be differential-mode.
I realize this won't catch on either
