M406 Mixer Fix Needed!
mattbeme
Member
Yamaha M406 mixer :      Similar to PM170 / 180
The Right Output is dead on the Main Output  XLR, 1/4" and headphone jacks.
The Right output Meter is also dead for the Main Right Output.
Schematics or Service Manual needed.
I called Yamaha and they claim that they have no listing for the Service Manual. Unusual for Yamaha.
Any sort of help with this matter is appreciated.
I do have some electronics knowledge and exprience with a soldering iron and VOM.
Matt B
Ontario, Canada
Pics of my M406 showing the PGM R board.
It is the Main Output board for the Right Main Bus. Yamaha calls it the Right 'Program' bus.
It is the card in the middle of the 3 larger ones on the left side of the pic showing the whole unit.
I checked all Resistors. = OK
I swapped the Left output card into the Right output card spot by connecting the Right card connectors into it.
Result: - Main Right output = OK
Headphone Output of Right Main Output = Nothing
Right Meter: Right Output Level = Nothing
Here is the Right Main Output board.  Called 'PGM Right'  (Program)
The 3 pots on the Right card are: from top to bottom:
-Echo Return Pan (FX return)
-Echo Return Level
-Right Program Output Level (Right Main Output)
Matt B
-I did a search of the Toshiba
TA7322P of which there are 3 on each of the output boards.
They appear to be linear style opamps.
See:  http://www.teaser.fr/~amajorel/at203a/ta7322p.html
--If  the problem could be with an OpAmp  maybe I could somehow wire in a replacement - which would of course be non-linear form.
I would need help with how to do this.    I'm not looking for a high-end fix:  as long as it results in something at least as decent as the original sound.
Matt B.
