Consumption of 9k Balancing Boards
Siegfried Meier
Ontario, Canada
Hey guys,
I've built up an 8 channel Sony MXP3000 mic preamp using the 9k PSU and 9k balancing boards.  I've built another one here that worked for years, but I didn't add any balancing boards to that so perhaps it's not drawing that much?  We're noticing that after 2 hours of use, all the pres seem to lose frequency response and sound like a telephone.  Is it possible the toroid isn't able to produce enough power?  But, is it possible to take 2 hours for this take effect?
How much power can these balancers possibly consume...?
Any help much appreciated.
Sig
No one eh?  Has anyone had issues with the Avel Lindberg stuff?  I was running my other 8 channel mic pre here for hours yesterday, even with +48v on every channel - no problems at all, and it was built with Amveco power transformers.
Is it possible that one mic pre is loading the rest down somehow?  But again, why is it taking 2 hours to go...?
Sig
Do you have room for larger heatsinks? Are you using a thermal compound? I had a power supply regulator where a little "burr" of plastic on the back of the regulator prevented a good mate to the heatsink. Maybe your heatsink is not "getting" the heat off of the component fast enough and it is building up.
