FINISHED PMEQP-1A3 in API500 format
safe as milk
sunny southampton,uk
hi
just finished up a few of these modules today & thought it's been a while since i
posted any of my 'hack work'...
a big thankyou to ian for the design of the filters, supplying the boards
& answering lots of really silly questions ;)
and a big thankyou to jeff steiger for the 312 boards which i then proceeded
to hack to pieces!
i used bbc input/output iron, melcor op amps from fabio way back when...
and hacked the card to be an api325 line amp.
i'll dig out the front panel file & try to post to.
pics...
wow, i didn't expect such a great response.
thankyou very much guys.
ian-if i sent you some yellow square ones to test then
you have in's & the out's...thanks again for inspiring these.
;D
;D
You sent me a couple of the square yellow ones but also some round ones with flying leads that look rather like the other transformer I can see on your PCB or is that something else entirely?
hi ian
yeah the yellow squares are bbc al94 1:1 outputs
and the others are bbc ll88asc 1:1 in or outs
we have a 60's pye console here with those as direct outputs
that sounds great.
i hope you find a happy valve home for them...
thanks as ever
justin
safe as milk said:
hi ian
that sounds great.
thanks as ever
justin
I recently treated myself to a decent inductance meter and spent a pleasant morning measuring the characteristics of all the transformers I could lay my hands on. The results were quite interesting and, when I have measured a couple more transformers that I expect to have in the next few days, I thought I would publish the results here. Needless to say, the BBC transformers are well specified.
I would love to see that!  How much does one have to spend on a decent inductance meter? I've looked on ebay and it seems most (of the cheap ones) don't go beyond 20 H. Too low for most transformers, yes?
They are not cheap. I got one made by Agilent which it cost me nearly 200GBP and there plenty of more expensive ones to choose from. It goes up to 200 Henries.
