Hi There,
I wanted to have some toughts on something i'm thinking to build for msyelf, i've already done some stuff and thinking regarding its build, meaning, worked on PCB's and as you can see some
3D Modelling just to get an idea of how all would fit and assemble together.
But some toughts advice, learning etc... is always welcome.
I wanted to have some sort of 51X lunchbox, an all in one solution, and tought this might make it happen, with 2 modules more than the Api one actually,
And if really want to go authentic, add a handle on the side haha.....
So basically it's a PSU Cartridge, that would take 3 module space, and so leaving 8 modules to be feeded.
Chunger had done something like that just for powering up a couple of modules if you remember?
Anyway there are a lot of things to take into account for building this, and i'm waiting on some informations to see if it would be doable on the way i tought about it.
But there are a couple of factors that i maybe omitted, and maybe a better way of doing all this? so that's why i'm asking for feedbacks and tought, pros and cons etc....
One of the main concerns and limitation i found is the Power transformer, it has to be a low profile one, the webshop here in France that makes custom Toroidals have Low Profile option,
and the max VA that "could" fit, because there is just maybe a mm tolerance to get the thing in (120mm open window on rack) well that would be their 120VA one. giving about lets say 1.4A fo the +/-24 and 16V rails on paper... and so it's dimensions are 119mm Diameter and 34mm high on paper also, I'm actually checking with them if they can do and garranty tight tolerances because real world could be way different.
Second Concern would be the weight of this transformer, on paper it's 1.5Kg huh.... and that would mean doing a tight and sturdy mechanical assembly...
On the PSU, the only PCB that has the cardedge is the Vreg module, i tought that having a sturdy mechanical fit between modules and the fpd attachement, would suffice in terms
of attachment? Maybe i'm tottaly wrong?
As for the PCB and the circuit, i sticked to the one that Silent Art had done for the circuit, but with a little less Voltage on the Capacitors side, since as you can on the sketchup drawing,
My disposition allows to have only max 35mm diameter and 40mm high capacitor, of course parralel some caps could do, maybe...
Options on the PSU would be Led and Fuse in front, Led beeing on the fused line.
I added A Neutrik Connector on front as well, for if wanting to use this module as an external unit, or it can even be a bench PSU just for feeding stuff, or maintenance stuff...
would need some simple DIY metal case, with a heatsink on one side or so, to help dissipation if going external and if i feel like taking the heat on a full 11 Space rack for random modules? Could be risky tough....?
And trimmers hole on front, to be able to fine tune the voltages.
As for the dissipation of the Vregs, i made a PCB for beeing able to home etch on double sided board, and this one has square holes to make the regulator pass under the PCB and to be able to connect directly on L Bracket, wich would have a 3mm aluminium plate on it to make a bigger and fatter heatsink, and since all would be tightened together with the front 3 Space FPD,
that would increase dissipation, now how much, only experimenting will tell...
The cabling would be a little tricky, but with a little discipline it should do, i made all connections on Molex, and some to solder directly...
But it will end up clean...
Of course inserting the PSU, would have to be done with the rack on the floor and facing up, for beeing able to insert easily and tightn everything before
putting the rack flat.
So any ideas toughts, critics are welcome. Maybe i'm over or not thinking of it enough?
T.
T.
