thekid777
Langevin AM16 input and output pads...
« on: October 18, 2012, 08:25:44 PM »
Hi, I read a lot of things but can't figure what would be best to have pads on the input and output of my AM16s
I read I would need a "T" pad, but then read other thing which say a "H" pad is needed to keep it balanced...
All I know is the AM16 want to see 600 ohms all the time at the inputs and outputs to perform correctly
Any help please?!!
Best regards
CJ
Re: Langevin AM16 input and output pads...
« Reply #1 on: October 19, 2012, 04:19:38 PM »
those guys have a pretty low gain already,
unless you are on the kick drum or a 200 watt marshall with a u67 in front,
If I can't fix it, I can fix it so nobody else can!
Frank's Tube Page: www.mif.pg.gda.pl/homepages/frank/vs.html
Guitar Amps: http://bmamps.com/Tech_sch.html
thekid777
« Reply #2 on: October 19, 2012, 04:30:44 PM »
50dB is not that bad!
I would like to have color options at the input and fine gain for the output to get it right in my daw...
CJ
« Reply #3 on: October 19, 2012, 09:00:40 PM »
hmm, the manual does say 45 db, i wonder how the input is strapped for that reading,
mine sounds more like 40 db,
here is an H and T pad Calculator
Bournes makes a 15 dollar variable T pad,
http://www.nu9n.com/tpad-calculator.html
« Reply #4 on: October 19, 2012, 10:30:03 PM »
U pad and T pad.
This has been covered in other posts a bunch, use the search function for millions of opinions.
AM16 can be strapped for 3 different input impedances, and at least 2 different output.  The manual can be found online if you don't have it.  At 600 out strapping it likes an output load between 600-1K, higher and it has a large treble boost from ringing.
thekid777
« Reply #5 on: October 19, 2012, 11:57:02 PM »
Thanks guys!
For Doug: You mean U pad at the input and T pad at the output?
Using these would make input and output unbalanced or I'm missing something?
Preamplifiers are already wired at 600 input and ouput.
« Last Edit: October 22, 2012, 10:37:52 AM by thekid777 »
PRR
« Reply #6 on: October 20, 2012, 01:12:15 AM »
It's transformer FLOATED. Not intrinsically "balanced".
Unless you need incredible precision, a simple pot is fine.
At the input, if leads are just a few inches, a 1K pot is fine.
Considering the OUTput level, and modern gear impedances, I'd use 620 ohm 1/2W fixed and a 10K pot across that to trim the delivered level.
thekid777
« Reply #7 on: October 22, 2012, 10:35:39 AM »
What are the resistors values needed to have a 2Kohm input and output impedance matching the AM16 input?
Sorry for my ignorance!
« Last Edit: October 27, 2012, 07:45:49 AM by thekid777 »
thekid777
« Reply #8 on: October 22, 2012, 10:41:53 AM »
Thanks Mr, the 620ohm fixed resistor help to avoid the problem Doug described?
"At 600 out strapping it likes an output load between 600-1K, higher and it has a large treble boost from ringing."
mikeyB
« Reply #9 on: October 23, 2012, 08:15:14 PM »
Hi CJ - trawlled the bourns website but couldn't find the T pad - do you have any part numbers?
As always - thanks in advance!
making better music!
CJ
« Reply #10 on: October 23, 2012, 10:32:21 PM »
i saw one on the Drip website, but now i can't finbd it  :-X
email Drip, i bet they will know,
cj
CJ
« Reply #11 on: October 25, 2012, 06:55:38 AM »
ok, too much permafrost,  :o  or was it the bubble hash?  :o :o
must have been the permafrosted And the bubble hash, i wish the feds would raid these places, costing me a fortune,  :o 8)  try this, take a small piece of black hashish, heat it up in the palm of your hand until you can mash it flat, roll it out just like a pie crust only smaller, then sprinkle in some good indica and roll it up like a burrito, then sprinkle some stativa on the outside to aid combustion, and you have the perfect hybrid steamroller load, ....what was the question?  why did i catch a cold?   :P
here is the Correct answer, my apologies to you and Drip who is wondering what the h you are asking about,  :D
BTW, has anybody done bidness with this place?
i was thinking about the API parts kit since i have a few raw boards to stuff,
30 bucks is pretty DIY unfriendly, but i love the conductive plastic Alps pots in the LA2a, if you have never used conductive plastic, you are in for a treat, smooth as silk, and they actually track a log curve a lot better than AB or CTS or whatever.
 bet this guy was once a forum member or still is,
that blue color that Bournes uses is a winner, kind of like Fluke yellow, only different, i wanna buy it just because it looks so nice, but then, it gets burried behind the panel so wtf, over?  :P
don't look to the left of that website unless you want your visa maxed out, too much good stuff in one place,
cj
http://classicapi.com/catalog/index.php?cPath=48
« Last Edit: October 25, 2012, 07:34:09 AM by CJ »
thekid777
« Reply #12 on: October 27, 2012, 06:11:31 AM »
What would be the resistors values needed to have a 2Kohm input and output impedance matching the AM16 input?
It's to run a U47 int the padded AM16
Thanks for your help
Bump :)
« Last Edit: October 27, 2012, 08:38:32 AM by thekid777 »
hoodun
« Reply #13 on: January 25, 2015, 06:41:12 PM »
I'm confused by this. So the correct way to wire this would be to  1 620 ohm resistor to the output and a 10k log pot from wiper to one of the pins going across to adjust from 620 - 9380?  Is this equal to or better than a 600ohm stepped attenuator? Makes sense to me with modern gear but others say they get too much treble with a 10k.
Rob Flinn
« Reply #14 on: January 25, 2015, 07:31:43 PM »
I used this output attenuator that Winston O'Boogie drew for me with my AM16. I used the right hand one with the 301R resistors, eems to work fine.
If you short pins K & H it puts it into high power output mode (+24dBm as opposed to +18dBm), but that also doubles the harmonic distortion & unsurprisingly doubles current draw from the PSU, therefore making the AM16 run hotter.  In the manual it says to keep them ventilated.
regards Rob
hoodun
« Reply #15 on: January 26, 2015, 10:34:46 PM »
Bump :)
I do not think this is possible with a transformer wired to 50 150 and 600 ohms.  If Im understanding your question correctly.
hoodun
« Reply #16 on: January 26, 2015, 10:41:16 PM »
This is how I wired my in the past (left side unbalanced). I also used a stereo log pot.
I think the right would be the same as putting a 620ohm between pins 2 and 3.  I am trying it this way with a 10k log pot to match the modern equipments imp. If the math is right this will give me between approx 585 to 600 in adjustment.
I also have a Mallory T Pad 600ohms (someone is selling a bunch on ebay right now). I may use this if I can get it to fit. Probably not though (its too wide).
The input pad is where I get confused. JLM has a variable pad with a 1k log and a resistor...  I know its simple but Im having brain fatigue from reading so many posts.
Also, has anyone added a pot to R1 to adjust gain? Is a 250ohm pot too much?
« Last Edit: January 26, 2015, 11:28:36 PM by hoodun »
Biasrocks
« Reply #17 on: January 29, 2015, 01:43:39 PM »
A fixed, switchable 20db 'U' pad is your best bet.
'Usually you see a switch which adds a 620 ohm in series to each
balanced input wire and a 169 ohm that shorts between the two.
This will give a 20 db pad. '
It's the best match and is recommended as the most transparent option.
There's a discussion here
http://groupdiy.com/index.php?topic=139.0
Mark
« Last Edit: January 29, 2015, 01:50:11 PM by Biasrocks »
http://SharktankPro.com
"I'd rather use an SPX90 than a UA plugin....." Joe Barresi
Biasrocks
« Reply #18 on: January 29, 2015, 01:45:04 PM »
Rob, is that 47R resistors on the other side of the pot? Is this how you wired yours or did you omit them?
Mark
Rob Flinn
« Reply #19 on: January 29, 2015, 02:22:01 PM »
I used this output attenuator that Winston O'Boogie drew for me with my AM16. I used the right hand one with the 301R resistors, seems to work fine.
Mark
I think I left them out, but it was a looong time ago now.
regards Rob
Last post October 22, 2006, 03:39:42 PM
by EmRR
langevin am16 trays
Started by Roly « 1 2 » The Lab
Last post May 29, 2005, 12:10:15 PM
by Roly
Last post July 22, 2007, 02:37:42 PM
by EmRR
Last post August 21, 2008, 01:58:37 PM
by pucho812
