hoodun
Active member
- Joined
- Sep 17, 2014
- Messages
- 41
Biasrocks said:A fixed, switchable 20db 'U' pad is your best bet.
'Usually you see a switch which adds a 620 ohm in series to each
balanced input wire and a 169 ohm that shorts between the two.
This will give a 20 db pad. '
It's the best match and is recommended as the most transparent option.
There's a discussion here
http://groupdiy.com/index.php?topic=139.0
Mark
So this along with an Output pot? I've read that a 10k pot on the output with a 620 resistor is best. How about wiring a pot up to R1? currently I am reading 580 ohms here (schematics say 680ohms). So I was thinking of wiring a 250ohm pot that will bring me to 680 and allow adjustment down to 430ohms. Or will a switch make more sense? ...I'd hate to wait for a pot to arrive in the mail for nothing.
