Well I have finally finished this project. It is my first design and is the main part of my dissertation that I am just starting to write.
The basic concept is 16 ch summing, with each stereo pair routable to a choice of two different gain stages. One stage is 990c + THAT 1646, whilst the other is 2520 + 2503. Each stage then has its own insert and level pot, before being summed for another master insert and then outputs & metering. The unit also includes a monitor controller, which can either be fed from the summing output, a front panel TRS external in, or a rear panel RCA external in.
There is a bit more background here:
http://www.groupdiy.com/index.php?topic=48614.msg615834#msg615834Thanks to not only the people that have answered any of my questions directly but everyone for all the background reading you have provided.
Even bigger thanks go to Tom Waterman for the guidance & inspiration, Jeff Steiger for all the great components, Sahib for helping with the machining & JLM for the PSU.
PCBs for 2 units
16 Ch THAT 1200 input board & external in/send&return board
Bus routing board, bus vol board, insert/bypass board
Main fader & headphone amp board, monitor section board
Gain stages. Left pair is 990c, right pair is 2520
JLM PSU
