For the sake of 4 Aux sends per channel it strikes me as easier to go active - there’s not many more components than in the passive methods anyway.But in a well designed passive system the variation in minimal and inaudible.
Horses for courses. Both are valid solutions. The particulars of the application determine which method best suits. Component count is just one factor.For the sake of 4 Aux sends per channel it strikes me as easier to go active - there’s not many more components than in the passive methods anyway.
Figured if OP is doing Neve style summing mix for main outs might as well do the same for the AuxesHorses for courses. Both are valid solutions. The particulars of the application determine which method best suits. Component count is just one factor.
1) did you determine that I was using passive mixing by something I drew on the schematic on post #19? or was it just a supposition? My believe was that as I draw it, it can't still be determined what kind of mixing system I was going to use, so I'm wondering if I understood that part correctly. I'm still trying to learn about this topic.
In theory VE nodes can be left floating which will improve noise when fewer channels are selected. However, the floating node is liable to pick up noise if you are not very careful so most people ground them to be safe. In a mixer with a small number of channels the noise penalty is tiny.2) for passive mixing, if I understand correctly, the bus resistor must be connected direct to 0V when that channel is switched off. So the way I drawn the MIX LR bus switches, is clearly wrong, since it leaves that node floating. If so, should I also change that arrangement for the other buses too, even if those will be using VE mixing?
Not necessarily. The Neve scheme, for example, slugs the bus so that the bus impedance is reduced to a value low enough to properly match the mix amp transformer input. This also significantly reduces the interaction of controls so that separate buffering is not required (and anyway there is a noise penalty for buffering).3) since passive mixing need low source impedance, should I add buffers on MIX LR, or the post panpot opamp IC7 already provides that?
It is not always necessary to use the Neve slugged bus method in a small mixer. Provided the value of the driving pot is about one fifth of the bus feed resistor there will be very little interaction between controls. So 10K pots and 47K bus feed resistors is a typical choice. There is very small noise penalty for using 47K resistors instead of, say, 10K resistors.
For the left and right bus feeds yes.Since I have an opamp (to implement active panning) between the panpot and the bus feed resistors, and the fader is even before that point, does this means that I just need the bus feed resistor with no pots, and hence there won’t be any interaction between controls?
As I was reading through this thread and reviewing your various schematic diagrams, I got to wondering.....while you are going through the process of building this "one-off" audio console, will you also be involved with all of the PCB designs, as well as all of the different types of mechanical designs that will be required in order to have this project actually become a "physical reality"??? If so.....there's going to be a whole lot of design engineering work involved!!!I started this new project: a small and simple console for my bedroom studio.
thanks for your warnings. I fully understand the complexity of this task. I'm not an electronic engineer as you may have noticed (I'm actually a software engineer), so of course this makes things even more harder. But this is my hobby and over the past 18 years I've been building and designing (many time I failed, many time I succeeded) a lot of audio devices, and probably the largest/most complex were analog and digital synthesizers. All the times I've also been involved in designing their large PCBs and mechanical aspects. I've also built tube guitar amps from scratch (included the CAD and the machining of the chassis and the wood working needed for the cabinet) and for some years I've been building electric guitars. So while I'm not really familiar with consoles, I'm not much scared by mid to large projects.will you also be involved with all of the PCB designs, as well as all of the different types of mechanical designs that will be required in order to have this project actually become a "physical reality"??? If so.....there's going to be a whole lot of design engineering work involved!!!
Have you already performed both the mechanical and PCB designs of large-scale electronic equipment before?
I know and I'm annoyed by that too, but the truth is that the schematics I'm showing here are just drafts that I'm doing with Eagle. Since those drafts are full of little circuit bits or alternate versions of those circuits that, for the sake of clarity, I don't show when posting here, designators make no sense right now. Luckily Eagle has a nice automatic "part renumber" feature, that I will run when I will got the various consolidated (..at least for a prototype) schematics.While reviewing your schematics, I couldn't help but notice that your component REFERENCE DESIGNATORS do not follow a linear sequential pattern. They jump around all over the place (i.e., R14 is placed before R9, etc.). Small stuff like this only adds to either inadvertent and/or more confusion later on down-the-road.
[Eagle has a nice automatic "part renumber" feature] -- My CADENCE/OrCAD program has a similar "Automatic Annotation" feature routine within it, but you need to be really careful when using it. These routines run on an X/Y-grid basis and if, for example, on the left-side of your schematic page there is just enough of a gap between two resistor symbols placed vertically above one another.....the top resistor symbol might end up being -- R7 and the resistor symbol directly below it is shown as -- R9 -- while resistor symbol -- R8 -- is shown over on the far right-side of the schematic. This is because the gap between R7 and R9 was just enough that the "Automatic Part Renumber" routine sees the right-side R8 as being the next component to annotate!!!Eagle has a nice automatic "part renumber" feature
that's a great help, I really appreciate it, thanks!By the way.....My CADENCE/OrCAD program has an "Import Eagle Schematic Translator" built into it, should you want to share your schematic with me so I can either review it and/or assist with reannotating it for you. > FREE!!! <
This might help - it’s for the BA283
thank you both for those documents, I'm studying!This might help. Basic info.
thank you really much! I have indeed a question: how do you use the 1272? as an outboard preamp or as it was used by Neve consoles (post summing amp)? I've seen some vintage 1272 and those had a gain trimmer that could be accessed from the front panel instead of the potentiometer/knob of the BAE 1272. I guess in the consoles the 1272 was used with fixed gain and an actual fader was wired after the unbalanced output of the 1272@Dimitree I have a BAE 1272 so if you need pics of anything specific let me know and I'll do my best to help you out.
