evil grill
Re: REDDI DI
« Reply #40 on: December 27, 2012, 03:45:37 PM »
The 1K pot on as the output level does not look right. Maybe it should be a voltage divider and go to ground?
Maybe I got it all wrong, but I thought of it more as a load-regulator for distortion-control. If distortion is reasonable for passive bass-pickups without the 1k pot I wo'nt use that in the final design. Less is less.
abbey road d enfer
Re: REDDI DI
« Reply #41 on: December 27, 2012, 04:24:38 PM »
I think what Ian suggested is to connect the pot at the secondary. It would present the xfmr with a nearly constant load.
Re: REDDI DI
« Reply #42 on: December 28, 2012, 06:09:11 AM »
I think you meant the input pot to be 1Meg not 10. The 1K pot should be wired across the transformer secondary as a pot divider.
You can use my poor man's tube gain make up PCB to build the SRPP. In the spirit of Christmas I am happy to donate 10 of these PCBs to builders of this project.
Re: REDDI DI
« Reply #43 on: December 28, 2012, 12:19:25 PM »
I'd love to have a go at building a valve DI Ian!  ::)
Chris
Re: REDDI DI
« Reply #44 on: December 28, 2012, 06:06:56 PM »
Chris
OK Chris, one PCB is reserved for you. 9 left.
Re: REDDI DI
« Reply #45 on: December 28, 2012, 08:39:00 PM »
Great stuff...thank you very much Ian :-)
Chris
lotus
Re: REDDI DI
« Reply #46 on: December 31, 2012, 08:32:46 PM »
Hi Ian,would you kindly send one to me as well.Also at the same time i'll put in an order for a few other boards.
I'll send you a pm in the new year.Tks
Re: REDDI DI
« Reply #47 on: January 01, 2013, 07:01:53 AM »
No problem. My pleasure.
Happy New Year
drask
Re: REDDI DI
« Reply #48 on: January 03, 2013, 07:34:15 AM »
Hi
I'm building a DI based on the 6N1P.
But I've some question about the ouput impedance and transformer.
B+ is 240v.
So, calculating the ouput impedance is :
(Rp * Ra) / (Rp + Ra) => (150 * 4.4) / (150 + 4.4) = 4.27K
Is it right? but is it not too small for the ouput impedance?
And another, I don't put a load resistor, do you think I need to put one?
Thank's to all !
Re: REDDI DI
« Reply #49 on: January 03, 2013, 09:54:51 AM »
Hi
B+ is 240v.
Thank's to all !
With a 150k Rp your plate current will be in the region of 1mA or so. At this current the tube's ra will be much higher than 4.4k. Also, the cathode bias resistor is not bypassed so the effective ra is increased by the cathode resistor * mu or about 90k. Your small signal output impedance is therefore in the region of  60k.
Small signal output impedance is not a good indicator of drive capability; for that you need current as well and you have very little plate current.
I would suggest you redesign the output stage for an idle current of about 10mA and bypass the cathode resistor. This will give you an output impedance much closer to the value you calculated and enough current for reasonable drive capability.
Re: REDDI DI
« Reply #50 on: January 24, 2013, 02:29:34 PM »
Hello all,
I've been speaking to the ever generous and ever knowledgeable ruffrecords via email.  The following schematic has been arrived upon (suggested by ruffrecords  ;) ).  Things to note are the tube type (6922) and transformer type (VTB2291).
I am currently creating a wiring diagram to show connections when using Ian's (ruffrecord's) PSU board and poorman's tube gain make-up.
I'm looking forward to making one/two of these!
« Last Edit: January 25, 2013, 05:31:38 AM by irfrench »
drask
Re: REDDI DI
« Reply #51 on: January 24, 2013, 07:06:18 PM »
I drew a tube DI too, following the advice of ruffrecords too.
I based mine on a 6N1P.
I'll be curious to compare the sound of the two different design and tube.
Irfrench, if you build it, please post your sound demo here :)
Re: REDDI DI
« Reply #52 on: January 25, 2013, 07:10:51 AM »
Awww shucks, now you've gone and done it.
I'll HAVE to build one now!   ;) ;D ;D
I'll be sure to record samples with it, probably bass (original huh?) as I'd like to compare it to a couple of other DI's too.
Ian (Ruffrecords) is a pleasure to speak to, and seemingly has an infinite reserve of patience.  A real Gent.
Anyway, I'll hopefully get on to it soon.  Will you be posting your schematic?
Re: REDDI DI
« Reply #53 on: January 25, 2013, 08:16:20 AM »
This will be very interesting comparison. A lot of EBay sellers try to make out the 6N1P is the same as the 6DJ6/ECC88/E88CC/6922. My own tests have shown conclusively that they are not. In general they are noisier and have greater distortion. If you want a real Russian equivalent to the 6922 and friends the 6HN23 is the one to go for. They are quite cheap and perform almost as well as the best 6922s.
I tend to think of the 6N1P as the dirty little brother of the 6922 so in this application I expect it could create an interesting sound especially on bass.
Re: REDDI DI
« Reply #54 on: January 25, 2013, 08:29:40 AM »
I am crap at mechanics so I am always on the lookout for ready made enclosures that give give projects a professional finish. So, does anyone know if there is an off the shelf enclosure like the one used by the REDDI?
Re: REDDI DI
« Reply #55 on: January 25, 2013, 08:35:18 AM »
I'm guessing the closest will be a valve mic PSU case?
I'm probably going to rack a pair of these up so haven't thought about it, but the first/proto will be done reusing an ugly ol' Maplin(gasp!) enclosure:
Thanks for all your help,
dmp
Re: REDDI DI
« Reply #56 on: January 25, 2013, 09:48:42 AM »
I'm going to use the PSU case from Dan at Collective Cases ($85)
Re: REDDI DI
« Reply #57 on: January 25, 2013, 09:59:11 AM »
Yup.  Those are the ones.  Beautiful.
http://www.groupdiy.com/index.php?topic=41963.msg618199#msg618199
In all honesty, now I've seen Dan does a stereo case  I'm thinking I may sack the rack mount idea off!  ;D ;D
Just get combi XLRs for the input and - bingo!
dandeurloo
Re: REDDI DI
« Reply #58 on: January 25, 2013, 10:31:56 AM »
Yeah, my plan was to be able to use the PSU cases for a number of things like this or a tube preamp case as well.  I suppose I could do a special run of them in a different color if enough guys could agree on it for this project.  Maybe Red?  haha
PROFESSIONAL CHASSIS AND FRONT PANELS FOR DIY PROJECTS: WWW.COLLECTIVECASES.COM
Dan Deurloo
www.collectivecases.com
www.risendrums.com
Re: REDDI DI
« Reply #59 on: January 25, 2013, 10:37:33 AM »
Massive Tease!   ;)
I quite like the grey TBH.
Do you have any pics of the stereo units? I'm wondering where the input and output level pots could/would/should go.
 8)
Last post April 04, 2008, 03:43:34 AM
by Sorr
Last post May 23, 2009, 11:15:44 AM
by Gus
Last post April 21, 2019, 06:15:01 AM
by fazeka
Last post February 24, 2019, 03:01:10 PM
by rock soderstrom
