Could you provide any schematics for the REDDI clone you made? And which output transformer did you choose?Hi All,
Just completed a Reddi tube bass di clone and it sounds rather nice, was also interested in building a Nobel bass di which uses two tubes and has bass and treble pots and a low cut switch.
Can’t see any schematics online so far so thought I’d ask here to see if this build or something fairly similar was possible.
I think it uses the 5963 tubes? Which I think is a variant of the 12AU7?
Also thinking about a Alembic F2-B
Any info would be appreciated.
How much iron did you use for the txf?I wound my own txf for the REDDI and consulted with CJ about it, schematics are all online and my thread should feature all info.
You won't tell me what lams or how thick you stacked them?I wound a special txf which is similar to CJs version, works well for me.
Ordered a comparable Edcor for <1/2 the price of the Cinemags. I want to measure and listen to them side by side. I also ordered a few bobbins and end bells, to wind a couple bigger ones on my own. I pretty much gleaned the specs (as much as I could) from reading CJ's old threads. I'm still missing some vital information. Luckily, I have "experiment" money, which had been set aside for purchasing some of his custom winds.My output transformers came from Cinemag. They are much smaller than I was expecting, I doubt they'll do what I need them to. But I'm experimenting, so it's fine. At least I will learn what doesn't work, and why.
