Telefunken
Please note that todays companies with 'Telefunken' in their name have nothing to do with Telefunken as you know it from the past. You can run a 'Telefunken blah blah' on your own. Check with TELEFUNKEN LICENSES GMBH in Frankfurt...
This can also be read on the german Wikipedia site - the US/english Wikipedia entry is not sufficiently precise here.
I wonder why? ???
Maybe because some people bought a licence to use the Telefunken name commercially and don't mention it on ther website.
:-X
The VF 14
Putting a glass tube in a can, paint it black, let it run in the given environment by adding a resistor and call it VF 14-whatever has nothing to do with research. The burn-in process doesn't get those tubes closer to a VF14 either. In the end you are still putting another (glass) tube into an U47. But the interaction between Tube and Transformer will be different and is complex.
The same is with the VF14s that pop up on ebay occassionally:
Chances are extremely high that you are buying a tube that has been rejected by Neumann in the past already.
When was the last time you saw a VF14 with an M stamped on it???
Are you shure this stamp has not been faked???
Grossers VF14FET is based on a FET can not be bought separately - it is part of a U47 service from Mr. Grosser.
Manufacturing VF14 steel tubes again won't happen - the tools and machinery are gone, rebuiling them will be too expensive for a niche market as condeser microphones are. :'( (but who knows how prices will rise on those tubes...)
When it comes to VF14 tubes or variants for a U47 clone: SIMPLY FORGET IT!
(and please ignore all the marketing BS you read or hear).
Just built yourself one of the mics that are available on this forum.
You will be suprised how good i.e. a well done G7 will sound in comparison to the 'boutiqe mics' (that are based on old Neumann or AKG C12 designs, too).
In the end those Mics are not different to a clone built by you or me - except for better or professional look, depending on your time, money and skills.
BTW: Did you ever count all the condenser mics that claim to be cloned / inspired / further developed variants of a U47 these days when one of the key parts has not been available for more than 40 years? :
