Hey Jose,
I feel you. I know what its like, I've been there. Hence I'll give this a quick shot, knowing your question calls out for lengthy answers that can go all kinds of ways. Please allow me to categorize:
A) You want this mic badly and fast
Then you should absolutely go down the complete-kit-path and order at micparts (I think they currently just have a C12ish kit on offer, great pricing when your're in the US) or micandmod.com (the PSU is already built, you'll be done in a net mic building time of 3 hours max, everything's in the box, no surprises, the chinese and czech parts are carefully selected, the evolved EF86-based circuit is not just a copy of the Archut designs and sounds great plus their support is awesome - a business model in it's own right and not just a ripoff as many members seem to promote here). If you want an even better sounding U47ish mic, you can easily swap components later on and upgrade capsule, transformer, capacitors and/or tube.
B) You want a high-end clone for not much more, don't mind altering hardware parts and time is not an issue
Then I'd personally prefer to build this circuit (links to BOMs for mic and PSU included)
Vintagemicrophonepcbkit.com
order
everything listed under "Vintage-Microphone PCB D-EF47 Project
" including the relay here
plus this body
MK47 microphone body kit (rev 2)
and search the web for
-a fitting PSU housing
-a fitting 60mm diameter shockmount
-a proper 7pin XLR mic cable (Gotham or the like)
-a couple of fitting new/NOS EF80(0/2) tubes to select your favorite/the least noisy one
Then order this classy German M7 capsule (cheaper than the D7 clone on vintagemic; it's being used in the current Telefunken U47 mic that sells for 11k)
Thiersch elektroakustik
Just email Rico Vetterlein (
info@mikrofonunion.com ) to order a STW7 red line capsule (PET) he's a great guy. The STW7 blue line PVC-version seems to sound a tad bit sweeter, but I would not want my capsule to deteriorate within years due to chemical decay.
Andreas Grosser's partner still has a couple of Haufe BV08 transformers left on stock, which he sells for just 200 Euros (which is about 60% of the original price). It's also being used in lots of expensive U47 clones like the Telefunken ones:
Haufe BV 08
Don't be fooled by the German captions saying "8:1" transformer: It isn't, the Haufe BV08 is 6.5:1 as in most of the later original Neumann U47s.
The only cons of this build are:
-this version doesn't have a multipattern switch: it's either cardioid or omni (the micandmod one and some others have 9-fold MP-switches)
-if the relay fails, you might grill your capsule due to over voltage
Good luck!
